Won't start
Old Dec 12, 2009 | 05:11 PM
97-7.3's Avatar
97-7.3
Won't start
I had a previous thread but site said I had exceeded postings on it.
97 7.3 Have had the truck 4 years, only problem was the fuel pump which I replaced about 9 months ago. I have noticed that it has been starting a little slower, not starter slow but a little longer to start.
Yesterday I was hooking up my trailer and the truck started idleing rough but after about 3 or 4 min it cleared up and was idleing normally, ran around all day without any problems. This morning it was 25 deg out, started the truck and it was ideling rough and in about 5 min shut down, I restarted and it ran about 20 sec and shut down.
I replaced the filter and tried to restart ... no start. Normally I hear a humming like a rear pump when I turn the ignition to on but not today, there is not a pump in the rear so I assume it has been the electrical tank switch mounted on the frame by the front tank. I checked the fuse and when using the tank switch in the cab can hear the unit ckick under the truck.
I checked the valley ... it is dry. The fuel bowl only is full about 1/2 now ... before replacing the filter it was full. Any suggestions?
Old Dec 12, 2009 | 05:20 PM
MADVAN's Avatar
MADVAN
Open the filter again and clean the fuel return screen.
Next would be to check the select valve.
Bill
Old Dec 12, 2009 | 05:23 PM
97-7.3's Avatar
97-7.3
Thanks Bill .... I haven't tried that but will in the A.M in fact didn't know that there was a return screen.
Is it in the fuel canaster?
Old Dec 12, 2009 | 05:59 PM
MADVAN's Avatar
MADVAN
Yes.
Its towards the top of the canaster on the regulator side. (drive side).
Dont think its your only issue but it will help the canaster fill with fuel.
Bill
Old Dec 12, 2009 | 06:04 PM
97-7.3's Avatar
97-7.3
Thanks again .... i was just reading a post about the FPR screen, should this be removed perodiacally as well??
Old Dec 12, 2009 | 06:09 PM
MADVAN's Avatar
MADVAN
Just clean it when you do a filter.
Just saw other tread
Check the transfer valve.
Are both fuel tanks 1/4 or more full?
Bill
Old Dec 12, 2009 | 06:34 PM
97-7.3's Avatar
97-7.3
One tank is full the other almost full. Where is the transfer valve you mentioned. I also noticed that the tach does not move when cranking.
Old Dec 12, 2009 | 07:07 PM
MADVAN's Avatar
MADVAN
Does the WTS lamp go on?
If not remove the wire off the fuel heater and replace the fuse.
Batts full charged?
Start with the basics.
Cross treads dont help.
Bill
Old Dec 12, 2009 | 07:28 PM
97-7.3's Avatar
97-7.3
Thanks Bill
I tried to saty in the other thread but when I tried to enter in the previous thread the site had an X by the thread with a note in the margin that I had 9 entries and that was the limit so I started a new thread.
Old Dec 12, 2009 | 09:10 PM
helifixer's Avatar
helifixer
if the tach isn't moving you either have a bad cps or bad cps wiring, the truck will not start if the cps is bad, it can't know when to fire the injectors.
Old Dec 13, 2009 | 07:45 AM
97-7.3's Avatar
97-7.3
Where is the cps located on the engine ... don't have a manual.
Old Dec 13, 2009 | 10:04 AM
DRRXR's Avatar
DRRXR
Old Dec 13, 2009 | 06:22 PM
97-7.3's Avatar
97-7.3
Thanks for all the help !!!
Replaced the CPS, canaster fuel heater fuse (it blew again .. must be short ) disconnected the canaster wire, replaced the fuse just as the replys to my thread suggested and it started right up.
AAAAAHAB
16
Feb 22, 2015 12:18 PM
CatchersDad97
57
Jun 7, 2013 03:17 PM
jga2z
Oct 31, 2010 11:38 PM
snowmannn
Jan 4, 2006 04:52 AM
BigSix1
Dec 18, 2003 04:18 PM
