Seat swap
Old 05-21-2000, 12:03 PM
Road Rage's Avatar
Road Rage
Road Rage is offline
Seat swap
Old 05-21-2000, 02:45 PM
bogborn's Avatar
bogborn
bogborn is offline
Seat swap
I have a '77 F-150 Custom. I want to swap out the seat for an early 90's bench. Will it bolt in or do I need to do some mods on the tracks. If this doesn't work, how late a seat will go in without any major mods. I'm limited on the amount of time the truck can be down as it is my daily driver.
Thanks in advance for any help ya'll can give me.
Bryan from Taylorsville, KY
'77 F-150 Custom 2 wd
351M and a 3 in the tree, life don't get much better than this, baby.
Old 05-21-2000, 03:33 PM
William's Avatar
William
William is offline
Seat swap
Bogborn, Use your sliders and all early 90 Ford bench seats will fit. I just installed a 93 bench in a 66. Mostly a bolt in deal.
William
Old 05-21-2000, 04:14 PM
BJs77F150's Avatar
BJs77F150
BJs77F150 is offline
Seat swap
I also have a 77 F150 Custom that I am swapping out seats in. I have researched this and have found that you can use the seats from almost any Ford truck up to 1998. All you need to do is save the seat slides that come with your old seat and bolt it to the new ones. Or you can get some really nice custom seats from some of the seat builders. Try checking out this site. http://www.sonnystruckseats.com
Hope this helps.
BJ 77 F150 4x4 Flairside 400/C6
Old 05-21-2000, 06:20 PM
red68ranger's Avatar
red68ranger
red68ranger is offline
Seat swap
All true. I put a '93 bench in my '68. It took maybe an hour. The new seats slides were mounted on it with bolts that screwed into threaded inserts in the seat frame, and the old seat's slides were mounted on it with nuts and bolts thru holes in the seat frame. The nice part was that the holes and inserts all lined up so I just knocked out a bolt here and drilled out a threaded insert there and the old slides mounted right on the new seat. A nice quick Saturday morning job.
Dan Blackwell
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Seat swap
