hey guys 1990 f150 4x4 auto e4od 351 355 gears and 35 in tires 135,ooo miles. was having shift problems from 1-2 slipage and bad shudder .code 62 says torque converter slippage. checked vss,mlps,shift solenoid etc all withing range and could hear solenoids engage. new filter and fluid and yes drained torque convertere. added dr tranny instant shudder fix. drove about 20 miles and she shifted like new. amazing.went another 10 miles or so and smoke was coming out the back. i pulled over and the whole underneath from the trans to the rearend completly soaked in trans fluid. and it was dumping from the front of trans( it looked like) i got in put in reverse and she went forward. all gears go forward now.bad mlps or maybe everything so wet at connectors? its 12 degrees here in toledo ohio could it have overheated trans? i removed driveshafts and dad towed it to his house. put driveshaft back in and still reverse is forward.even neutral went forward. front seal bad or just blow by from heat? overdrive works fine and no engine light. will pull codes this weekend again. any ideas? thanks guys
oh it leaked bad about 2 yrs ago in the summer when i was pullong a small camper but i thought it was coming out the dipstick tube. to cold to crawl under it now and its so wet.under there, also truck has been babied. in excellent shape and never off road or abused. not driven often as i drive my tracker with 34 in tires all the time. truck gave no previous sign of trans problem. just driveing one day in the city amd she started shiffting hard from 1-2 and engine had to rev to get it in gear. a few years ago was shiffting hard from all gears and that was a bad vss. but no other signs
