Piston Direction
Old Dec 11, 2009 | 10:09 PM
74bruce's Avatar
74bruce
Piston Direction
I read a Mop@r book once that said you can get less rotating assembly friction/restriction if you install the pistons in backwards...180 out. It stated that this may cause a knock from the wrist pin, but this was normal and it reduced cylinder friction, therefore increasing HP.
I'd never heard of this. It is possible? If so, then would it work in a 5.0.
I don't think it would hurt balance, but I'm sure there is a reason for the arrows/markings for the front.
Anyone ever heard of this or done it?
Old Dec 15, 2009 | 10:30 AM
woodsnake's Avatar
woodsnake
This is an ancient myth. You will not gain anything, or, nothing measurable for a street driven engine. Or, a race car either, for that matter.
Lots of "old school" information has been proven false since the internet has come along. (gotta have some back pressure, to help it run)
There is so much information now available that it is mind boggling! Not to mention the higher quality, lower cost replacement parts that are available.
It used to be that a three angle valve job and getting your stock heads cut for a 2.02 valve was the cats *** for a street Ford. But, so many folks would say that a 302 can't possibly need that much valve! Or that you can't build a 302 big enough to need a 750 Holley. Way too much carb for that little engine!
Want to go fast? Aluminum heads, or even cast heads from World are cheaper to buy out of the box, than trying to get your stock heads rebuilt. (Unless you get a family or similar discount).
Look at camshafts these days. You can get a custom cam ground for around four hundred bucks.
Sorry, don't mean to rant, I just came across this while looking for some IAC info, and wanted to share...
miashley150
17
Mar 21, 2016 09:48 PM
miashley150
Mar 9, 2016 10:19 PM
bbsitum
1997 - 2003 F150
May 16, 2015 08:01 AM
nojoke327
Dec 19, 2013 09:02 PM
peppy
Oil & Lubrication
Jan 18, 2004 10:40 PM
