ebpv?
Old Dec 11, 2009 | 06:45 PM
zo6man's Avatar
zo6man
No , have not checked fuel pressure. no cel. its as if the ebpv is actvated, but its not. once the truck is completely warmed up it will drive and shift fine up to 30mph, then bam, feels like a damper closed. will not go over 30, will just spew black smoke if I hold the pedal down.
Old Dec 11, 2009 | 06:46 PM
zo6man's Avatar
zo6man
Yes MADVAN
Old Dec 11, 2009 | 06:58 PM
zo6man's Avatar
zo6man
yes MADVAN, feels like tc lock. but this would only happen when the temp wasn't up, now, I could drive my truck for miles everything feels fine until 30mph, then it fells like I downshifted into 1st gear, its an automatic, even if I kept the pedal down, it would just spew black smoke. before this would happen, I could come to a complete stop, then take off again and everything would be fine once the temps were up, now no matter what the temp is, she wont kick in after 30. I'm trying, no mech, just a plumber.
Old Dec 11, 2009 | 10:48 PM
c00nhunterjoe's Avatar
c00nhunterjoe
ok 2 things, "spews black smoke" and "bone stock" dont go together.
my money is on a clogged cat or a faulty map or baro sensor. there are only a few things that can cause spews of black smoke along with no power on a stock tuning truck. without a scan tool it is a little more difficult to diag but a simple test is unplug your map sensor and drive it. you will get a cel but test drive to look for a change in performance.
map sensor i slocated in the top left of this picture right on top of the heater housing, 3 wire connector with a rubber hose that goes right to your intake.
Old Dec 11, 2009 | 10:56 PM
c00nhunterjoe
z06man, if you really are here to try and fix your truck then pm me your phone number. i will walk you through some easy diag on your truck but i need some cooperation on your part and a history on your "replaced parts list" its a bit late tonight but i will be home tomarrow for a while. i am willing to donate my time to try and help you. the ball is in your court
Old Dec 11, 2009 | 11:00 PM
mountaineer27's Avatar
mountaineer27
did you put regular gas in it? seen trucks do that. there ok in first gear but as soon as it shifts the motor dies. even if its just a little bit mixed. are you getting any codes at all?
Old Dec 11, 2009 | 11:16 PM
pinned's Avatar
pinned
How is the turbo?
Old Dec 12, 2009 | 04:49 AM
Talyn's Avatar
Talyn
Man, just a giveup. Prolly something simple as a sensor too.
Ebpv even if unpluged can close.
Sensors coon suggested are all good starts.
Old Dec 12, 2009 | 04:50 AM
Talyn's Avatar
Talyn
Old Dec 12, 2009 | 06:09 AM
Brown Falcon's Avatar
Brown Falcon
Pull the downpipe off to see if the EBPV is indeed closed or open, even if unplugged it can close and might need to be wired open.
Check the VSS (Vehicle Speed Sensor) on top of the rear diff. Pull it out and if it's dirty wipe it off with a clean rag and reinstall. Or put in a new one. Also check the wires going to it for damage.
Transmission Range Sensor on the driver side of the tranny. Could go bad and the truck won't know what gear it's in.
Originally Posted by Talyn
Man, just a giveup.
Come on Talyn, I know you have better advice than that...
Old Dec 12, 2009 | 07:58 AM
rideracelivemx7's Avatar
rideracelivemx7
is there any possible way you can get a video for us when it starts to do it? our flatbed duraturd does that same thing but its a fuel rail issue and you can keep it to the boards and it wont go above 2grand or 30mph and the engine seems loaded up, is your engine loaded up when it happenes? im sure if we can hear what its doing, it will make this Diag process much quicker
Old Dec 13, 2009 | 09:51 AM
Talyn's Avatar
Talyn
I was calling him a give up.
or a quitter.
I woudln't tell somebody to give up.
Old Dec 13, 2009 | 01:19 PM
  #28
Brown Falcon
or a quitter.
Oh, ok... sorry. Misunderstood you there.
Old Dec 13, 2009 | 07:17 PM
  #29
Talyn's Avatar
Talyn
Yea. I am usually pretty good about my commas, and my words.
Sometimes I misspell things. But, if you read it. It is correct. =)
Old Dec 13, 2009 | 10:05 PM
  #30
Oversize's Avatar
Oversize
Did you check the FPR screen if its plugged up enough itll bog the power down and cause smoke, That and plugged up CAT will cause lots of smoke with no power. Also Good idea wiring the EBPV open to ensure it.
