Cab corners
Old May 24, 2000 | 12:04 AM
elsmith's Avatar
elsmith
Cab corners
How Structurally important are the rear lower cab corners on a 67 f100? There are rust in mine and I don't have access to a welder so i was thinking about fiberglassing them. Will fiberglassing work? Thanks
Old May 24, 2000 | 04:18 AM
jowilker's Avatar
jowilker
Cab corners
EL, You can run the truck a long time with bad corners, as it is more cosmetic than structual, but I'm sure you want your truck to look good. You can buy replacement corners to do your repairs. I have read where guys here have used compounds to stop rust. The body guys that I know say that you have to cut it out and replace it to stop the rust. I know that I have seen good looking paint with the bubbly rust reoccuring under it.
Carolina Classics carries replacement corners, 800-598-4211.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old May 24, 2000 | 11:58 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
Cab corners
fiberglass will work just fine, if you take the time to do it right
Old May 25, 2000 | 12:14 AM
BJs77F150's Avatar
BJs77F150
Cab corners
If you remove the rusted metal, and apply something to stop if from rusting more, then apply the fiberglass, it should last indefinately. I just replaced my cab corners on my 77 F150 Custom with new ones. It really wasnt that expensive to have them done at a welding shop. Hope this helps.
BJ 77 F150 Flairside 400/C6 4x4
Old May 26, 2000 | 07:07 PM
elsmith's Avatar
elsmith
Cab corners
Thanks for the replys i sandblasted the rust off and put the fiberglass I will add a little bondo on later sand it and primer.
Eric
Old May 27, 2000 | 01:52 PM
PetesPonies's Avatar
PetesPonies
Cab corners
topmoo
18
Dec 27, 2012 07:55 PM
oldmanrvr5
Jan 6, 2011 09:23 PM
pburress
Paint & Bodywork
Jun 20, 2005 11:16 PM
Racerdave
Jun 5, 2003 12:06 AM
Beave
Aug 15, 2001 07:56 AM
