I need frame specs doing a frame off project and
the frame is ready to be painted but want to check
the frame at a shop but not even the frame shops can seem to help me on specs. to old........22years aint' ole....lol searching nite and day for 72hrs. minus sleeping.......tried
good nite to all......78-79 Bronco Frame Specs. where are you ????
Frame specs are the factory dimensions of the frame. Length, width and heigth of the different sections of the frame. I learned that when I worked in a body shop.
If your local Ford dealer can't help then start calling around to the body shops, there should be someone that works on "old" trucks and has the specs.
