Engines
Old May 23, 2000 | 05:12 AM
ayoung_2's Avatar
ayoung_2
Engines
Old May 26, 2000 | 07:41 PM
ttwelder's Avatar
ttwelder
Engines
How do you tell the difference between a 390 and 360 without tearing them apart? And are the parts interchangable? Sure could use some help on this one, Thanks
ttwelder
Old May 27, 2000 | 03:31 AM
jowilker's Avatar
jowilker
Engines
tt, you can use a wire or small dowel through the spark plug hole and measure the stroke.
Steve Christ's book says that a 360 is 3.50 and a 390 is 3.784.
It is very highly likely that the truck had a 360 factory installed.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old May 27, 2000 | 11:57 AM
ttwelder's Avatar
ttwelder
Engines
Thanks John, that was valuable information, I appreciate it. I am going to check it out.
thanks
Old May 27, 2000 | 10:19 PM
HiMe's Avatar
HiMe
Engines
You could drop the oil pan and inspect the casting numbers on the crank shaft. Truck 390's have 2U, 3U, or 2UA numbering.
Other than the crankshaft, connecting rods, and in some cases the pistons, the engines are identical. Hence parts are interchangable.
Jim
Old May 28, 2000 | 05:50 PM
ttwelder's Avatar
ttwelder
Engines
Thanks for the info Jim, I wanted to know if you could change the transmission yoke from flange to the slip yoke, if they interchanged, sounds like it will work but don't know this stuff.
Thanks
Fred
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
