CHITTY CHITTY BANG BANG! HELP!!!
Old Dec 11, 2009 | 04:49 AM
Copedawg's Avatar
Copedawg
Well not quite chitty chitty bang bang, more like buck buck die!
I was chuggen in to work at ZERO-dark-thirty and my truck bucked 2wice and died at about 70mph and 20 miles in to the commute.
I pulled over and cranked it a few times with no "fire". I could not tell if I was getting smoke or not b/c it was to dark. I unplugged my ICP and it fired up (I have 2 10K pots but I have taken them out of service for the winter so don't let the sig fool you). It is parked right now w/ICP still unplugged.
What do I need to do next?
Thanks
COPE
Old Dec 11, 2009 | 06:17 AM
FARM69's Avatar
FARM69
I've had problems with the 10k mod to, but not as bad. It seems that the wires get hot once you exposed them and it tends to act up. Mine would run eradically sometimes until I played with the ICP wire.
Try putting some heat wrap around it if you haven't already.
Old Dec 11, 2009 | 07:17 AM
Copedawg's Avatar
Copedawg
I have them soldered and heat wrapped in to a militiary grade quick connect cannon plug. I wonder if the problem maybe at the actual plug itself? I will look around again now the sun is up.
Thanks for the suggestion, FARM69!
Any other takers?
Old Dec 11, 2009 | 07:59 AM
Action4478's Avatar
Action4478
Its your oil cooler ....
Actually , when you get the chance, look at the sensor itself , it may have oil seeping from it . Replacing it may help ,a cheaper test than an IPR ..Make sure the IPR nut is on & the wiring to it isn't shorting out..
Old Dec 11, 2009 | 10:35 AM
Copedawg's Avatar
Copedawg
Thanks FARM69 and Rick!
Rick," Its your oil cooler .... " REPS SENT!
Thanks for the places to start. I shot some coil cleaner in the ICP and the IPR. I'll see what happens. I did not see any oil in the or around the ICP. How do these components cost normaly?
Old Dec 11, 2009 | 11:35 AM
Copedawg's Avatar
Copedawg
I just drove it home, about 30 miles and no chuggen or bucken and it did not die. I spose I will just keep an eye on it.
Thanks again!
Old Dec 11, 2009 | 11:40 AM
rodneywar's Avatar
rodneywar
The icp costs about 180 bucks at ford.
Old Dec 11, 2009 | 11:47 AM
Copedawg's Avatar
Copedawg
WOW! That little POS is a buck 80!!??
I don't think it is bad but I don't know how to troubleshoot it and I don't know the symptoms of a bad one. I may pick one up the next junkyard trip I go on.
Old Dec 11, 2009 | 12:06 PM
Action4478's Avatar
Action4478
They are on flea bay for a bit less from time to time , & you can try partsguyed.com ..A sponsor here . Could have been a bad connection there also ...
Old Dec 11, 2009 | 12:13 PM
Copedawg's Avatar
Copedawg
Rick, what are the symptoms? Is it a go/no go type component, like run or no run when it is bad?
ALSO, if it runs better w/o it, why is it there? AND why does it "pop wheelies" with 20K ohms slowing it down. Lastly, who put the Dip in the dipty dip doowip and who put the Ram in the rama lama ding dong?
Thanks
Old Dec 11, 2009 | 12:27 PM
Action4478's Avatar
Action4478
There are tests for the ICP ,scanner & VOM. I 'll see if I can find them . The PCM reads the ICP to regualte the IPR . It may have lost signal ,when the PCM is not seeing ICP as expected (unplugged) it uses other inputs to regulate injection...
Old Dec 11, 2009 | 12:40 PM
Action4478's Avatar
Action4478
When the ICP out right fails , it is supposed to set a CEL .
I believe (could be wrong) that , if the reason IT quit was a sticking IPR , unplugging it makes the PCM call for an ICP of 700 to start , a little higher than ICP is at Idle .
Old Dec 11, 2009 | 12:51 PM
Copedawg's Avatar
Copedawg
Thanks Rick! I unplugged the ICP not IPR. If I unplug the IPR will it do the same? Also what is that component just above th IPR? It is a sensor w/two wires plugged in to metal tubing that I assume has some kind of liquid.
While I have your ear: I was just out there w/brake clean. While the engine was running, I sprayed around the turbo, Y pipe and other places where the intake is. My thought behind was, if there is a leak I would hear the idle kick up some. I did not notice any change in the idle. Did I just troubleshoot/test the intake connections?
EDIT: My CEL light does not work. I think it may be burned out!!! TRUE!
Old Dec 11, 2009 | 01:24 PM
Action4478's Avatar
Action4478
It will stall
I would guess that is the EBP sensor
While I have your ear: I was just out there w/brake clean. While the engine was running, I sprayed around the turbo, Y pipe and other places where the intake is. My thought behind was, if there is a leak I would hear the idle kick up some. I did not notice any change in the idle. Did I just troubleshoot/test the intake connections? if you are looking for a boost leak , then no
Turn on the key , & look for the CEL to flash ...
Old Dec 11, 2009 | 01:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
No if you unplugg the IPR the truck wont start. and that is the solenoid of the IPR with the connector.
Tugly
49
Sep 13, 2013 11:59 AM
kwizman
2004 - 2008 F150
Sep 5, 2013 01:10 PM
DesertStorm
Offroad & 4x4
Aug 7, 2008 07:39 PM
wesmansr
Mar 15, 2005 12:23 AM
chitty
1983 - 2012 Ranger & B-Series
Jan 4, 2005 07:53 PM
