Locking hub question?
Old Dec 11, 2009 | 01:09 AM
thunderbolt427's Avatar
thunderbolt427
Does it hurt anything to leave the hubs in lock position on my 96 F150 4x4? I needed to make a sharp turn yesterday and the front was binding up bad. I shifted out of 4 wheel drive to make the turn and never shifted back to it. I drove about 40 miles with the hubs locked. Thanks
Old Dec 11, 2009 | 01:14 AM
zxwut?'s Avatar
zxwut?
If you have the selector in 2H, you can drive all over at any speed with the hubs locked, it'll just use more gas. It doesn't actually engage 4wd until you select it. Locking the hubs just engages the wheels.
Old Dec 11, 2009 | 01:17 AM
Hitokori's Avatar
Hitokori
no keeping them locked will just lower ur fuel mileage because of having to turn the diff. and all that stuff on the front axle instead of freely turning on the hub.... make sence? FYI if u strip the ring and pinion gears in the rear u can drive around with the front...
Old Dec 11, 2009 | 01:37 AM
thunderbolt427
Thanks for the replys. I will switch it back, just didn't know if it hurt anything.
Old Dec 11, 2009 | 03:41 AM
A1C DiMaggio's Avatar
A1C DiMaggio
having them locked all the time can also cause mild uneven wear in the front wheels. but you would have to drive for quite a while to really notice the wear
Old Dec 11, 2009 | 05:01 AM
mrbubble's Avatar
mrbubble
Why is the wear uneven? Only one wheel turning the differential?
Old Dec 11, 2009 | 08:21 PM
PatsPOS's Avatar
PatsPOS
T-bolt...I'm guessing you've been driving 4WD long enough to know how much fun making a sharp turn with 4WD engaged is. If you disengaged 4WD to make the turn, and it was binding up front anyway, I'd hazard a guess that you need to look at your front axle shaft u-joints.
As others have said, driving with the hubs locked (AFTER you fix those u-joints! ) doesn't hurt anything but your gas mileage.
Pat
Old Dec 11, 2009 | 08:28 PM
HrdDrv's Avatar
HrdDrv
I lock my hubs in for a few miles to keep everything lubed up, but no 4wd on dry roads, and never in a turn on dry. Lawns, fields, etc, yes, dry pavement, no.
Old Dec 11, 2009 | 08:45 PM
Conanski's Avatar
Conanski
The front axle u-joints may not have the same operating range when locked as they do when free, I have noticed this on my truck and I know these joints are in good shape.
Old Dec 11, 2009 | 09:05 PM
Volvo92906's Avatar
Volvo92906
Assuming this is just a general thread by everyone else's responses......
So, I am pretty new to 4wd. Ive only used it for trailing and now I am in the snowy north. If it snows hard and there is still that packed snowy sheet on the road or whatever and I take my highway route to school/work can I have it in 4h? (this is hypothetical odds of me needing it are going to be slim with my tires and driving)
Old Dec 11, 2009 | 09:09 PM
Hitokori's Avatar
Hitokori
yes u can drive in 4H lol u can drive it every day in 4H or 4L if u wanted to. as long as u run the same size tires front and back of course
Old Dec 11, 2009 | 09:19 PM
Volvo92906's Avatar
Volvo92906
Well, I know the gearing and tires need to be the same size cause thats bad if theyre not. But, I didnt think you could go fast in 4L. Its more of a crawler speed. But, thank you for the info on the 4H. Its just good to know if need be.
Old Dec 11, 2009 | 09:28 PM
HrdDrv's Avatar
HrdDrv
IF, IF you have it in 4hi, or 4lo, and you try and turn a corner, you'll find out the difference. Going straight isn't the issue. Locking the front in will cause the front diff to lock up the wheels and they will hop/skip, unless they are in mud or snow.
4hi is ok for regular speed, just watch the cornering. 4lo is for pulling/plowing.
Old Dec 11, 2009 | 10:10 PM
Hitokori's Avatar
Hitokori
no they wont unless u have a locker in the front.... the front diff works like the rear one... only difference is the teeth on the ring and pinion are reverse cut
Old Dec 11, 2009 | 10:43 PM
HrdDrv's Avatar
HrdDrv
If I put my rig in reverse, and turn sharp left or right, will my rear hop or jump?
Every 4-wheel drive I've ever driven with it in 4-whatever has jumped when you turn a tight corner. It has to do with the ratio of the rear/transfer case/ and the front rear ratio conflicting.
I'm sure there's another response in here about this.
I can be proved wrong, my therapist say's so.
