Locking hub question?
Old Dec 12, 2009 | 01:19 AM
A1C DiMaggio's Avatar
A1C DiMaggio
Originally Posted by mrbubble
Why is the wear uneven? Only one wheel turning the differential?
because the wheels are locked, both wheels turn at the same rate no matter what. i work with a 25,000lb loader at work that is front wheel drive, permanant locking diff and the solid rubber tires have to be replaced every 3 months b/c of the uneven wear. it gets so bad the whole thing shakes when you drive it.
have you ever tried to turn an ATV when the front wheels are locked? its ridiculously hard, usually, the outside wheel spins faster than the inside wheel, this prevents excessive wear. with the diff locked, it wont allow the wheels to spin at different rates
Old Dec 12, 2009 | 07:22 AM
Volvo92906's Avatar
Volvo92906
Yeah.. I was always told you cannot turn on dry pavement with it locked in as well. Since both front and rear diffs are essentially locked together it would slip or hop. A vehicles (dogtracks?) during a turn so the front is wider than the rear. The rear is trying to go one speed, the front another, and it meets at the transfer case/transmisson.
I can understand it being bad with lockers also. Heck, even with just the rear locked it hops. Whatever anyone agrees with, I will not turn on dry pavement locked in. I wouldnt need the 4wd if it was dry out anyhow.
I was just wondering about the speed thing, but its good this was brought up also.
Old Dec 12, 2009 | 10:09 AM
Conanski's Avatar
Conanski
I regularly take my truck up to and over 70mph in 4hi or with the front hubs locked on snow covered or partially covered roads in the winter. If all the joints up there are in good shape and are well greased there won't be any issue.
Old Dec 12, 2009 | 12:33 PM
HrdDrv's Avatar
HrdDrv
Thanks guys, for backing me up on this. As I stated before, I wouldn't give halfassed advice to anyone.
Old Dec 12, 2009 | 10:15 PM
mrbubble's Avatar
mrbubble
Ahh, ok. Thanks for the info!
