How does this stupid tensioner work? Please Help!
Old Dec 15, 2009 | 01:49 PM
starmilt's Avatar
starmilt
Can you post a picture of your tensioner. I have never seen one that is so much trouble.
Not familar with a hydrolic tensioner though most applications are spring loaded. Is that the only idler on your engine.
Old Dec 15, 2009 | 02:02 PM
Chicken_Fried's Avatar
Chicken_Fried
I will get a picture up in the hour.
No its not its not the only idler on the truck. there is one below the tensioner.
Old Dec 15, 2009 | 02:40 PM
Chicken_Fried
Old Dec 15, 2009 | 03:14 PM
starmilt's Avatar
starmilt
Can you get a wrench or crescant on the ear where the shock hooks on the idler and push to where it collapses the shock. is it possible that shock is stuck in that position.
Have you tapping it with a hammer to see if you have any movement at all.
Old Dec 15, 2009 | 05:22 PM
9473's Avatar
9473
Originally Posted by Chicken_Fried
Chicken Fried,
Yours is the same as mine. If you referred to my previous post and the tensioner will not flex [towards the passenger side] with the socket on the pulley wheel then your tensioner is shot. It should flex and then return when pressure is released.
Old Dec 15, 2009 | 07:20 PM
Chicken_Fried
Originally Posted by 9473
Chicken Fried,
The hex bolt (15mm) that holds the pulley on just spins when I try and turn it passenger and comes off when I try and turn it driver.
Also I tried loosening the torx bolt but that just wanted to strip itself.
Old Dec 15, 2009 | 07:45 PM
9473's Avatar
9473
Did you take the bolt out and look at? It sounds like it's stripped.
Old Dec 15, 2009 | 09:50 PM
Chicken_Fried
Not yet, I figured that it in a sleeve of somesort so that the pulley can still spin. I am going to check on it tonight and will let you know.
Old Dec 15, 2009 | 10:21 PM
87crewdually's Avatar
87crewdually
The steel bolt is thread into aluminum tensioner mount. I'd pull the bolt out and check the hole, you may have it stripped out and will have to helicoil it.
Next step I'd do too is take the shock off and see if you can get it to collapse in a vice or small press.
ConvertedFord
Jul 23, 2013 10:22 PM
DGM
May 17, 2012 07:36 PM
X_man
Sep 17, 2009 08:34 PM
walkman
1983 - 2012 Ranger & B-Series
Nov 8, 2006 09:40 PM
byo71
May 3, 2006 02:30 PM
