Sponsored by: Real Truck
Misfire
Old Dec 10, 2009 | 03:16 PM
leogla's Avatar
leogla
Misfire
This is a SD 250 5.4L I be feeling this small misfire on the past 3 weeks. Today it get worse. I change spark plug around 4 month ago with afthermarker ( autolite)
It posible that sparkplugs are go off?
Also can i check if i got a coil bad by unplug when engine are running?
Thanks for any futher answer.
Old Dec 10, 2009 | 10:54 PM
wallz's Avatar
wallz
The easiest way to check is to get a scanner on it. Now if that still doesn't show any thing, as sometimes when the are kinda on the way out they don't show a code. Get a spray bottle with water and even put some vinegar in there and spray around the plugs/boots while the engine is running and then run the scanner again. This should show you which cylinder is the problem.
Did you replace the boots when you replaced the plugs? Usually cracked boots is what starts a lot of these issues. Also when replacing the boots you should use dielectric grease.
Went724
Sep 10, 2014 05:53 AM
dimitriaudio
Modular V10 (6.8l)
Apr 9, 2010 08:36 PM
jsims11
1997 - 2003 F150
Apr 17, 2009 09:29 PM
cashfordy
1997 - 2003 F150
Mar 27, 2007 09:46 PM
nallen731
Modular V8 (4.6L, 5.4L)
13
Oct 16, 2005 12:49 PM
