few more ?s
Old Dec 9, 2009 | 11:16 PM
jlang's Avatar
jlang
few more ?s
im building a performance engine, should i go with the elec waterpump?or mechanical
also on the top of the block towards the back in the vallley were the lifters are there is a part that looks like a v or y, with 2 threaded holes in it the block im building doesnt have any screws in it but the other does and it looks like there adjusted to a certain point.
1.what does this do and what is it called
2.are the screw set to anything?
Old Dec 10, 2009 | 03:54 AM
Slip ford man's Avatar
Slip ford man
I just installed an Edelbrock victor series alum. waterpump. I did away with the fan/clutch, and put in two 14" procomp electric fan's wired with seperate relays. I mounted the fans on a thin alum home made shroud, she runs with a power increase feel for sure.
Old Dec 11, 2009 | 09:28 AM
jlang's Avatar
jlang
but wat about the other thing the cite i found it on said it redirects oil but how?
Old Dec 11, 2009 | 11:18 AM
cobraguy's Avatar
cobraguy
Those are pipe plugs for the oil passages. Just transfer them over to the new block. Or get new ones and install. I'd have to look but I think they are standard 1/4" pipe plugs. I put a dab of blue locktite on them when I install them.
Old Dec 11, 2009 | 01:45 PM
mark a.'s Avatar
mark a.
You need to remove those and clean real good it there.
Old Dec 12, 2009 | 06:19 AM
monsterbaby's Avatar
monsterbaby
Just so you know what that actually is. those holes are where Ford drilled the oil passage that carries the oil from the drivers side of the block to the passengers side lifters. the pipe plugs are to close off the end so it's a sealed passage. It's an oil gallary for getting the oil from one side of the block to the other.
MattyJessome
23
Oct 13, 2010 05:57 PM
Greyf100
21
Sep 8, 2010 05:33 AM
C-Leigh Racing
Mar 10, 2009 10:40 PM
krankshaft
Aerostar
Sep 14, 2005 09:37 AM
erikl85
Mar 26, 2003 06:15 PM
