Gas mileage problems
Old Dec 9, 2009 | 11:03 PM
Hunt89's Avatar
Hunt89
I have a 89 f150 300 i6. When i first started driving it about 2 years ago i was getting about 16mpg but now im lucky to get 13mpg. Im driving the truck the same as i did 2 years ago. I have a K&N cold air intake and a flowmaster. ( im not driving it faster or harder because it sounds good) . Can y'all give me any tips please?
Old Dec 9, 2009 | 11:17 PM
skyfox10's Avatar
skyfox10
Have you been doing routine maintenance? AKA Plugs, Wires, Dist Cap, Fuel Filter?
These are what I would start with.
Old Dec 9, 2009 | 11:21 PM
Hunt89's Avatar
Hunt89
yes. I have replace the dist cap and fuel filter.
would replacing the vacuum hoses help?
Old Dec 9, 2009 | 11:29 PM
94MustangGT's Avatar
94MustangGT
Try pulling codes.
Don't forget plugs and wires. Than K&N needs to be cleaned and re-oiled every 10-15K miles too. Tires? The right tires, pressure, and alignment can affect things. Clean out the throttle body for the fun of it.
Old Dec 10, 2009 | 12:03 PM
TexasGuy001's Avatar
TexasGuy001
Get rid of the CAI. Its sucks in warm underhood air. The factory air box with the I6/460 tube is better. It actually gets cool air. Just run this with a good replacement filter not KN.
I agree about maintanance. Check the air in your tires. What plugs are you running?
Why would you want to replace vacuum hoses?
Old Dec 10, 2009 | 12:39 PM
darthice's Avatar
darthice
you would get better milage from a MAF Conversion they have them for all tranny types now Interactive Systems & Technologies Mass Air Home Page or dunnerite.com i am going to do my truck when i get the cash to do it.
Old Dec 10, 2009 | 07:25 PM
skyfox10's Avatar
skyfox10
you could also check compression, might just be rings/seals are 2 years older.
does MAF give better mileage? This is a serious question, i'm not trying to argue.
i have two trucks, one rolled of the line in march 95, the other in Aug 95. Both are 351W/E40D/4x4 both ran the exact same (literally) 31" tires.
Everything is the same on these trucks except:
March Truck: Speed Density/3.55rear/long box
August Truck: Mass Air/3.08rear/short box
both get exactly the same mileage, 12City/13Hwy. Does this mean that There maybe something hurting my mileage on the Aug truck? How big of a difference should you see?
Old Dec 10, 2009 | 08:57 PM
Conanski's Avatar
Conanski
Both trucks should do a lot better than that, have you recalibrated your speedos for the bigger tires? I'd also say that 3.55 gears is about the minimum for 31" tires and you could see milage improvements with a gearing change depending upon how fast you drive on the highway.
Old Dec 10, 2009 | 10:09 PM
Hunt89's Avatar
Hunt89
i didnt think of the cai like that. just got the front end realigned and the air pressure is good. I have standard motorcraft plugs. they are original hoses and they look pretty wore.
Old Dec 10, 2009 | 10:12 PM
Hunt89's Avatar
Hunt89
I have not recalibrated it. How would you do that?
Old Dec 10, 2009 | 10:54 PM
skyfox10's Avatar
skyfox10
What type of K&N Intake do you have?
the old K&N FIPK's for the SD trucks.
or one of the newer ones:
57-2542 - K&N 57 Series FIPK, Performance Intake Kit (SD)
57-2543 - K&N 57 Series FIPK, Performance Intake Kit (MAF)
The newer filters have come a ways, and don't pull in as much warm air as the oder ones.
I have not recalibrate the speedos, I remember checking awhile ago and finding something like a 6% difference between stock and the 31's so I didn't find it significant (does this sound right?), plus i keep toying with 3.73's and didn't want to recalibrate them twice. When I get on the highway, i average 80, partially because it's necessary to stay in the powerband when i go through the mountains, but also I do enjoy the speed.
Old Dec 10, 2009 | 11:00 PM
Hunt89's Avatar
Hunt89
That is the same one i have. So should i look in to one of the newer ones? Btw thanks everyone of all the help.
Old Dec 11, 2009 | 03:40 AM
TexasGuy001
If its an exposed filter under the hood thats what it does, suck in warm air.
I don't have anything made by KN anymore. It lets more dirt in and it doesn't flow that well as it gets dirty. Also, all the cleaning drying and oiling is just a pain.
Also the fact that it can damage the MAF sensor is not worth it to me.
I had the KN FIPK for mass air but it is basically the same thing on my truck for a little while. Its a waste of money. All it did was decrease fuel economy and cause my truck to run really bad on hot days.
Even if the engine is not stock, the OEM air box especially with the I6/460 tube flows adequately.
Old Dec 11, 2009 | 03:50 AM
TexasGuy001
Many car manufacturers have TSB's about KN.
Most of the European car guys as well as the hot rod deisel guys won't run KN either. I also read that the exotic car shops won't use them either.
Here are a few links.
ISO 5011 Duramax Air Filter Test Report
Technical Articles: Debunking the K&N Myth - Why OEM is Better
Air Filters, Including My Thoughts on K&N
There are filtration and flow tests at the bottom of this link.
Air Filtration Test
Old Dec 11, 2009 | 03:52 AM
TexasGuy001
I believe that since your truck is an 89, you have to change your speedo gear to recalibrate for the tires. The 92-96 can actually be reprogrammed.
