coil packs
Old Dec 9, 2009 | 09:29 PM
bcompton35603's Avatar
bcompton35603
coil packs
My 4.6L Windsor has a coil pack on each side of Engine, so what are the the COP (coil on plug) everyone is talking about? are these just on 5.4 and bigger engines?
Old Dec 9, 2009 | 09:36 PM
kerim1's Avatar
kerim1
i have a 4.6 expy and it has cop's (coil on plug) that i recently replaced
Old Dec 9, 2009 | 10:45 PM
97ExpGuy's Avatar
97ExpGuy
Coil Over Plug (COP) means one coil per spark plug/per cylinder
Coil Pack will look like this:
Old Dec 9, 2009 | 11:29 PM
alloro's Avatar
alloro
This used to be the case, but in the early 2000s the 4.6 was changed over to have COPs as well.
Old Dec 10, 2009 | 05:40 AM
bcompton35603
ok, I got it...I changed out both coil packs in March along with plugs and wires. Any idea why water is getting in first plugwell on each cylinder bank? have noticed it both times I went to change plugs
Old Dec 10, 2009 | 12:18 PM
97ExpGuy's Avatar
97ExpGuy
More than likely because you did not seal off the plug boot with dielectric grease. When the rubber boot slips down in the plug well, there should be a lip toward the top of the boot that sits on the cylinder head. (You can see this in the picture I posted). Use a good amount of grease under that lip and that will help seal the well. Other users have also put a ring/bead of grease on the outside of the boot as well to ensure moisture or water does not reach the plug and cause problems.
About the issue of both front wells filling with water boggles my mind at the moment. I do know that on the driver's side, the thermostat housing sits above plug 5 (first plug on driver's side) and if it leaks, coolant runs right to that plug.
I'd try sealing those areas off again and see of you have any more problems.
Old Dec 10, 2009 | 01:01 PM
bcompton35603
didn't see a photo on the spark plug boots
Old Dec 10, 2009 | 02:31 PM
97ExpGuy's Avatar
97ExpGuy
I meant in the first post I did here in your thread. In the mean time, here's a better photo:
Look at where the boot just starts to bend to the left. That 'lip' on the boot that's wider than than the boot itself is where you put the dielectric grease. This lip is what sits on the cylinder head.
Now, I do want you to note this boot is from a 5.4L, but the point I want to make is that there is a lip on the boot, whether 4.6 or 5.4 that comes into contact with the cylinder head. If this point is not sealed off, or the boot dries out, moisture can get under it and short out the plug.
royeco
Jan 25, 2017 01:26 PM
kunard333
1983 - 2012 Ranger & B-Series
18
Aug 24, 2014 11:17 PM
Jose A.
Aerostar
Apr 11, 2014 12:35 PM
tristopher1234
1997 - 2003 F150
Jul 19, 2010 01:47 AM
breakinator
Modular V8 (4.6L, 5.4L)
Sep 17, 2008 03:00 PM
