EBPV
Old Dec 8, 2009 | 06:29 PM
pat_da_man's Avatar
pat_da_man
EBPV
will it hurt my truck to drive for a few days with the wires uncliped from on top of the ebtv sensor? i think is been acting up lately and havent had time to ake it appart
thanks
Old Dec 8, 2009 | 06:32 PM
big poppa's Avatar
big poppa
I don't see why not, but why do you think its acting up, whats it doing?? Welcome to FTE by the way..
Old Dec 8, 2009 | 06:34 PM
pat_da_man's Avatar
pat_da_man
well just from other threads
power loss and weird sound rushing air or somthing. does it when cold clears up when fully warm
Old Dec 8, 2009 | 06:59 PM
rbaker6336's Avatar
rbaker6336
you can also disable the EBPV by unpluging it at the turbo base
Old Dec 8, 2009 | 07:03 PM
pat_da_man's Avatar
pat_da_man
so either way it wont damage anything?
Old Dec 8, 2009 | 07:07 PM
clem1226's Avatar
clem1226
sounds like it is functioning properly. The function of the EBPV is to buildup heat in the cyl's and help the engine warm up faster...hence it only activates when the engine is cold and will cycle occasionally until the engine is up to operating temp.
someone please correct me if I mispoke and welcome to FTE
Old Dec 8, 2009 | 07:14 PM
big poppa's Avatar
big poppa
No, it won't damage anything, you just won't have use of it but the shhhh or airplane sound your hearing is normal, that helps to warm the motor up faster.
Old Dec 8, 2009 | 07:24 PM
pat_da_man's Avatar
pat_da_man
well the problem for me is that its like on off on off unless i'm hard on the throttle it will do this even if plugged in until the temp reaches the halfway mark, id be fine with it if it was intermittent but i think its a liitle exessive
Old Dec 8, 2009 | 07:44 PM
big poppa's Avatar
big poppa
Well, you got to remember, its getting cold out there now and its going to come on more frequent. Mine comes on at startup and when I depress the brake pedal, it shuts off and when I go down the road and maybe park and let it idle and its not up to temps yet, the EBPV will kick in again giving me that airplane sound out the tailpipe. When it sticks, like it did to me once before, I didn't let it warm up, I just took off out of my driveway and when I pulled out into the roadway, I mashed down on the pedal and the truck wouldn't move, sluggish bigtime, coasted into a store parking lot and after turning around there, it unstuck, giving me power again. Thats how you know if its sticking, no power..
Old Dec 8, 2009 | 07:57 PM
Hubbler's Avatar
Hubbler
Yes mine is doing the same thing as yours is pat. I understand what it does but mine is coming on even when the engine is up to temp and has been for a while. It wont do it when I lay into the throttle. But I think mine is quite excessive as well. I live in michigan and yeah its getting cold so i figure it will be on more but not when the engine is up to operating temp? Only happens below 2000 rpms. Idk if this is normal or not.
I just recently aquired this super duty as I have been wanting a diesel/stick for a long time. So this is my first. I was searching for this problem and I just came across this forum and had to join. So Hello to all!
Old Dec 8, 2009 | 08:00 PM
Hubbler's Avatar
Hubbler
Also I had a guy that owns a diesel repair shop here look at and he said it is even excessive and shouldnt be doing it. He couldnt remember what caused it off the top of his head but said he had a service book from ford that had what caused it. He didnt get to it today but said he would tommarow. Ill post what he says.
Old Dec 8, 2009 | 08:01 PM
pat_da_man's Avatar
pat_da_man
same as mine with the rpms
i think i'l clean the tube as suggestedin the other thread i read and see if its better i think it just keeps doing it too long while i'm commuting in the morning
this is what i'm gonna do on the weekend i hope
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
thanks for everyones advice
Old Dec 8, 2009 | 08:08 PM
big poppa's Avatar
big poppa
Welcome both of you guys to FTE, glad to have yaa's. Well, if there is a problem I hope you guys figure it out, your both starting out on a good note with Guzzle's maintenance pages, good luck..
Old Dec 23, 2009 | 11:30 PM
pat_da_man's Avatar
pat_da_man
well looked at the tube seemed fine. now that it has warmed up a bunch its much better. guess it was just normal. thanks for everyones help
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
