Fuel Pump
Old Dec 8, 2009 | 04:36 PM
jowilker's Avatar
jowilker
Fuel Pump
I just installed a new Airtex fuel pump from Advance Auto and I can't stop a leak in the fittings going up to the carb. Beginning to wonder if it is in the pump body.
I reused the old fittings, then replaced them with the new that were included included and it still leaks.
I will try a new line next.
John
Old Dec 8, 2009 | 08:09 PM
Argess's Avatar
Argess
I've used that yellow plumber's teflon tape with great success...NOT the white stuff.
It is best if you can get a seal without it, but the yellow tape does work.......has been many years and no leaks with it.
EDIT: I better explain a little more. I have found that sometimes a factory made flared fitting seals against the screw-in fitting, but not against the raised dimple inside the carb (or fuel pump in your case). I use the tape on the outside threads of the screw-in fitting.
Old Dec 9, 2009 | 03:35 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
John if I read that right ? Sounds to me like since both your old fittings and the new ones both leaked.. Sound like some bad machining in the port of the new fuel pump...
Old Dec 9, 2009 | 05:54 AM
jowilker's Avatar
jowilker
I picked up a new line last night. I will bend it and mount it to see if that is where the problem is.
I don't see any issues with the line but for $5.00 it's worth a try.
John
Old Dec 9, 2009 | 06:17 AM
Argess's Avatar
Argess
Oh-oh Russ....we are both named John....which one are you "talkikng" to?
In my case, it wasn't the pump, it was leaks at the carb. Due to using a fuel log form Summit that had flares formed in a press.....with sort of a parting line, I think.
Summit Racing SUM-G3120 - Summit Racing® Adjustable Fuel Lines with Pressure Gauge - Overview - SummitRacing.com
Old Dec 9, 2009 | 10:24 AM
jowilker's Avatar
jowilker
One would think that since I have John in my post, and that I made referencer to both the old & new fittings that he replied to my original post, he was replying to me, but I could be wrong.
John
Old Dec 9, 2009 | 01:05 PM
jowilker's Avatar
jowilker
The body split where the nipple screwed in for the up line, going back to AA.
John
Old Dec 9, 2009 | 03:48 PM
jowilker's Avatar
jowilker
After a 40 mile road trip to another store because the local didn't have another, I have the 2nd pump installed without a leak. Hot DAMN!
I am damn tired of gas in my face and down my arm.
John
Old Dec 9, 2009 | 04:22 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If there's one thing I hate more than gasoline smell clinging to my skin, it's DIESEL!
(or kerosene, or fuel oil)
Glad you got it working John
Old Dec 9, 2009 | 06:05 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I used to use Sunoco 260 as aftershave. I do miss the stuff.
John bummer on the cracked pump housing.
Old Dec 9, 2009 | 06:08 PM
sc00ter's Avatar
sc00ter
gas in the armpit is the worst.
Old Dec 9, 2009 | 06:25 PM
RapidRuss's Avatar
RapidRuss
John
Glad you got er fixed there John... had to be in the fuel pump beings both lines leaked..
And to the Other John...LOL..Are you also having fuel leak problems too ? As I dint see your post...
Old Dec 9, 2009 | 08:23 PM
Argess's Avatar
Argess
No leaks. In my enthusiasm to be helpful, I got confused. Sorry about that. Glad you got it fixed, John!!!
Old Dec 10, 2009 | 05:15 AM
jowilker's Avatar
jowilker
I guess the big issue is that changing a pump should be straight forward bolt up exchange. It still leaking makes me want to drink some Sunoco 260.
Take it back and the guy tell you "I can have you one tomorrow" is another butt rub.
John
JOHNSHO
Oct 12, 2011 05:14 PM
John - NNY
Nov 13, 2010 10:37 AM
Obtuse1
Aug 30, 2004 03:06 PM
luv2sled
13
May 6, 2002 09:24 PM
