Sponsored by: Real Truck
Is this hitch a worthwhile upgrade?
Old Dec 8, 2009 | 11:52 AM
bpounds's Avatar
bpounds
I think it's the same, except for the chassis cab. Finding a Ford 2.5" receiver would be a good way to go, assuming it will fit.
Old Dec 8, 2009 | 01:01 PM
System's Avatar
System
Prolocutor
I thought the welds would be weaker. Then I looked at the Reese 2.5 18k Titan hitch which is rated higher than the stock 350 2.5 hitch. Same deal. The cross tube terminates at the side hangers. So, I guess that system of hitch design can't be that weak. Check it out. http://www.etrailer.com/pc-H~45297.h...eid=2009301027 18k hitch with 2500 tongue weight. No sense in upgrading to that though as it's built beyond the trucks capability. That's why I was looking at the Curt.
Old Dec 8, 2009 | 01:12 PM
PERFORMANCE RED's Avatar
PERFORMANCE RED
I have a Putnam XDR class V on my truck. I just realized that the are out of business now.
Intersting read about Curt and Putnam.
Putnam hitch MFGR closes doors!!! - Diesel Place
Class V – The XDR – Xtra Duty Receiver - the heaviest rated 2" receiver hitch in the industry. The XDR Series Class V receiver hitches can handle the BIG loads...up to 15,000 pounds with 16,000 pound weight distribution and tongue weights up to 1,600 pounds. The XDR is made for only the toughest SUV’s and pickup trucks on the market today.
•2" square receiver tube
•Up to 15,000# Weight Carrying MGTW
•Up to 16,000# Weight Distribution MGTW
•"No Drill" applications available
•Polyshield Finish
Old Dec 8, 2009 | 01:17 PM
System's Avatar
System
Prolocutor
•Polyshield Finish
Looks to be the same specs as the Curt.
Old Dec 8, 2009 | 01:29 PM
PERFORMANCE RED
The only problem I had with mine is the paint falling off in places. I took it off and had it powder coated black and all is good now.
Old Dec 8, 2009 | 02:20 PM
System's Avatar
System
Prolocutor
And the Curt says it's power coated too.
Old Dec 8, 2009 | 02:46 PM
msalyer's Avatar
msalyer
I have had Curt hitches on a couple vehicles and they are very good hitches. That being said I would not change the factory one on a Super Duty. It is also a very good heavy duty hitch.
Old Dec 8, 2009 | 05:07 PM
System's Avatar
System
Prolocutor
PS: To clarify why I wanted to upgrade, the trailer we are ordering has a dry weight (useless, I know) of 7375 and dry hitch weight of 890 with a GVWR of 11050. I also tow an enclosed snowmobile trailer that I think loaded with our atv's or snowmobiles is over the 600# limit on my stock hitch for tongue in WC mode. I guess I may pass on the Curt and if I do upgrade go with the 18k Reese.
Old Dec 8, 2009 | 05:27 PM
bpounds's Avatar
bpounds
I think you will be fine with the stock hitch. I sent reps your way for taking the time and concern to be as safe as you can. I wish more RV'rs on the road would do that. Dang, I see a lot of unsafe rigs in the outdoors.
Old Dec 8, 2009 | 06:08 PM
nphillips's Avatar
nphillips
As far as the hitch goes, Curt brand is ok. I work at a RV dealership and we recommend Reese over Curt. Reese has a much more longer life span then the Curt brand.
Old Dec 8, 2009 | 06:38 PM
System's Avatar
System
Prolocutor
Thanks man! You know, I figure it's better to have too much and not need it than to have everything maxed out or close to it.
Old Dec 8, 2009 | 06:41 PM
System's Avatar
System
Prolocutor
Interesting. Thanks for the info. It seems they have a coating under the powercoating which Curt doesn't. I also noticed that the shipping weight of any Reese compared to a Curt with the same specs is significantly less.
Old Dec 10, 2009 | 01:34 AM
  #28
aldridgec's Avatar
aldridgec
I think you will be better off not only keeping the factory hitch but using the WD equipment as required to be in the weight ratings. Upgrading the hitch and not using the WD setup would be a bad idea IMO.
Old Dec 10, 2009 | 06:13 AM
  #29
System's Avatar
System
Prolocutor
I always planned on using WD. I don't think you were following my post.
Old Dec 10, 2009 | 08:33 AM
  #30
WhiteEx's Avatar
WhiteEx
I removed my Ford factory hitch (it is for sale) and replaced it with the SuperHitch from TorkLift. Torklift's Original SuperHitch The reason I did it is because I need a 48" extension in order to pull my boat when the camper is on the truck. I also used TorkLift's extension. SuperTruss :: Hitch Extension from Torklift
The new hitch is unbelievable strong.
