4x4 low range question
But my question is when I put it in 4 low and start off in 1st gear the engine revs up high imediatly and the truck moves but not with the pull I'd expect. It seems to pull harder in 2nd or 3rd gear when in 4 low, just wondering if it just feels this way because the engine is red linning in first gear so quickly, or is clutch slipping, or something in transfer case slipping??
Thanks
mat
also with snow possible coming wondring can I drive around in city with hubs locked, but truck in 2wheel drive on dry/clear roads, and than just put it into 4 high or 4 low on the snowy icy roads. Wil this damage anything?
Thanks again
Yes you can leave the hubs locked at all times. Will wear more parts faster and hurt the Mpg's some. Northerners tend to do that. I have never minded getting out to lock them in.
Think of a ten speed bicycle, in the lowest gear possible, and notice how fast you can turn the pedals immediately, and how slow you actually go. Same principle.
Now, as far as running around with the hubs locked,,,,,feel free to do so. You will not wear anything out any faster.
The rear axle does not wear out very quickly right? It can last for several years and those are always experoencing power.
Some full time systems do not even have locking hubs.
Many owners lock the hubs in the winter and unlock them after the entire season is over.
Another, newbie question, just double checking, with manual hubs I don' t need to bother driving in reverse after going back into 2 wheel drive. That's just an auto hub thing, correct?
I did not intend to point fingers at "right" or "wrong", simply stating that nothing can be worn out from turning, or rotating.
Since the front output is not engaged, the front end components are just along for he ride, and really there is no strain, nor is there any torque applied to any of the components. This means that the amount of wear applied to them is mimimal.
Turning radius is no affected, since the steering stops are the only thing that can determine this.
If the front axle has some sort of traction device this limited turning, or other similar issues could present a bit of an issue, but none that would prevent the operator from going about a normal day to day drive.
When I ran a Detoit up front, I often drove the truck with the front hubs engaged.
Even today, when I am headed up to the trailhead, I will lock the front hubs early and drive with them locked, so that I can throw some lube around, and get some temp in the front end before I hammer on it off road.
Locking the front hubs and driving on the highway is a great way to get the tepms in the front end up a bit.
Mileage loss is truly minimal.
wont hurt yuor steering any like 75F350 said its the steering stops that will do that... but DO NOT adjust those stops, unless you find a higher radius steering box or something, if you adjust those stops to try and gain turining radius they become useless and now the steering box acts as the stops which can be incredibly hard on it and you usually wind up eating through the steerin boxes by doing this, not to mention this could also cause the axle joints to bind up, thats why the stops are there, not to lessen the turn radius but to protect the steering components
BTW the mazda junkbox trannys came in F250s but only behind the 302...other than that all F250/F350s were the ZF i believe (yes even the 300) and i think all f150s were the mazda (an f150 with the 351 might have a zf but i dont think so)
As for your low range function, sounds normal to me. If you had a real load, you would feel the power AND you would have to shift out of 1st gear sooner too. If my hubs were unlocked, I would drive a lot in 1st gear/4x4 low for creeping stop and go traffic with my manual trucks.
Thats funny. I do the same thing in my Yota. When I drive a Yota 4by in heavy Los Angeles traffic, I often pop the case into low range with the front hubs unlocked. Bumper to bumper traffic is no problem at such low speeds, and I seldom have to shift out of second gear, or use the clutch.
I can apply the brakes and almost come to a complete stop without ever pushing the clutch pedal.
Ive also gotten pretty good at shifting back onto 2wd high range on the fly.
Probably why I can get so many miles out of a clutch.
Yeah, gotta get around somehow. The convenience of the little truck was too much to pass up. Ive always had a Yota around.
This was a great deal at 500 bucks. Too good to pass up.
I threatened to keep it stock and have done a good job, but it will get a Beard suspension seat (bench) and a solid front axle, along with a full cage. Ive already thrown in a late model axle with an e-locker, chro-mo shafts in the back, and just have to make some diac brake brackets to finish that.
That will be the extent of this build. Nothing crazy, just a nice little driver.
We know I cant leave anything stock, lol.
$500 is a smokin' deal, they are worth their weight in gold up here. Only ones that cheap are totaled......
Is that one the 22re or the 3.0 headgasket eater?....
I had taco for about 6 months, but at 6'5" it was too tight for me, and I didn't like the payments. Kinda wish I had one now though.
