DSL Modems
Old Dec 7, 2009 | 02:10 PM
mantta's Avatar
mantta
Question DSL Modems
Can I connect more than one DSL modem to a single phone line? Will it degrade the service if I do?
Thanks!
Old Dec 7, 2009 | 02:12 PM
MisterCMK's Avatar
MisterCMK
Why do you want to use 2 modems?
Old Dec 7, 2009 | 02:13 PM
mantta's Avatar
mantta
Laptop in the garage.
Old Dec 7, 2009 | 02:19 PM
Furyus1's Avatar
Furyus1
The easiest thing to do is get a router. If your laptop support wireless internet, get a wireless router but make sure to set encryption on it so you don't become the neighborhood "hotspot"...
Old Dec 7, 2009 | 02:24 PM
mantta's Avatar
mantta
My nearest neighbor is a half a mile away.
Old Dec 7, 2009 | 03:15 PM
jim henderson's Avatar
jim henderson
Your modem talks to a single modem on the other end of your phone line at the phone switch office. Almost surely two modems talking at the same time would confuse the other end, but I am not up to date on DSL technology and protocol.
In anycase, there is almost surely no need for two modems driving one line since a wireless router will handle just about any need. Unless you are a heavy duty gamer and need maximum speed on each line, the wireless is fast enough, even for videos.
I have been able to use a wireless modem between our two warehouses, a block apart. The signal is weak but it works. You can also buy range booster antennas for the wireless modem, this can often boost the signal enough to overcome problems. Range is very dependant on the router, and the receiving PC and interferance between the two.
I am pretty sure you can get at least a couple hundred feet since I often am able to connect to neighborhood modems if I am away from my home or office.
Just my opinions,
Jim Henderson
Old Dec 7, 2009 | 04:38 PM
MisterCMK's Avatar
MisterCMK
How many wires do you have between the garage and the house?
Old Dec 7, 2009 | 11:45 PM
Frankenbiker's Avatar
Frankenbiker
It takes a little digging, but for point-to-point wireless applications, one can buy directional antennas that can incease WiFi range to nearly half a mile. And the newer cards and routers use some sophisticated signal processing techniques to increase that range even further.
-blaine
Old Dec 10, 2009 | 05:16 AM
06supercrew's Avatar
06supercrew
Use a wireless router and if your laptop or desktop does not have wi-fi you can get a card to plug in to a usb port. That would be the easiest and probably the cheapest. If using a laptop it would also allow for use at other locations ie: under shady spot, porch, etc.
Old Dec 10, 2009 | 06:54 AM
mistakenID's Avatar
mistakenID
A second modem would not connect anyway. The modem has to be provisioned by the mac address in the ISP database. If you just stick another modem on the line, it will try to connect but a connection will not happen.
As stated above, you can go wireless router or wired and pull cat 5 cable to the garage.
ddrumman2004
Jul 17, 2009 10:43 AM
cjben
Jun 10, 2009 04:08 PM
sierraben
25
May 1, 2006 08:52 PM
mantta
20
Mar 5, 2005 09:28 AM
Munkey
Jun 15, 2004 03:26 PM
