speedo is jumping
Old Dec 6, 2009 | 11:02 PM
crestfallinman's Avatar
crestfallinman
speedo is jumping
my speedometer randomly started jumping around once it hit like 30 mph on my way home tonight
how would i go about diagnosing if its the whole cluster or the VSS? and where is the VSS? if thats not too much of a dumb question
Old Dec 7, 2009 | 01:08 AM
DBGrif91's Avatar
DBGrif91
I don't think there's any way to test the VSS, but you may just want to check to make sure the connections aren't dirty or corroded. It should be located on the transmission- just trace the speedo cable back and it should hook right into it.
Old Dec 7, 2009 | 06:17 AM
fbama73's Avatar
fbama73
The VSS on my '96 is located on the rear differential. You don't mention if your truck is an automatic or a manual trans, but if it is an auto, and you're noticing the truck dropping out and back in to OD, that's a pretty good sign it would be the VSS.
Old Dec 7, 2009 | 07:43 AM
subford's Avatar
subford
The VSS sensor is mounted on top of the rear end.
You test it by putting a volt meter on the the wires going to it at the RABS Data Link Connector under the hood and slowly increase speed to 30 miles per hour. Check to see if the voltage goes from zero to 3.5 AC volts smoothly.
Note:
Pin 4, +, input, low, wire 523 R/PK
Pin 5, -. Return, high, wire 519 LG/BK
From the shop manual:
NOTE:
Only wiring harness end of connector is to be probed.
Connect Digital Volt-Ohmmeter to Pin 4 (speed in +) and Pin 5 (speed in -).
Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
RABS Data Link Connector is the ABS Test Plugs in the diagram below:
Old Dec 7, 2009 | 07:56 AM
crestfallinman
it is an e4od 2wd
so is it on the diff or on the trans im confused now haha
Old Dec 7, 2009 | 08:46 AM
subford's Avatar
subford
Originally Posted by crestfallinman
it is an e4od 2wd
It is on the diff.
ramrod7373
15
Apr 1, 2013 11:37 AM
tappit01
Dec 16, 2012 08:43 AM
ramrod7373
Dec 14, 2012 08:51 AM
460
Offroad & 4x4
May 14, 2012 06:17 PM
BRay09
23
Jul 6, 2011 09:15 PM
