boost gauge flutter
Old Dec 6, 2009 | 11:01 PM
rivrrunner's Avatar
rivrrunner
boost gauge flutter
posting for friend 97 F350 7.3
Low and high end performance issues...boost gauge flutters on high demand...bad wheel?? Bearings?? can u replace wheel only on stock 97 turbo??
Old Dec 6, 2009 | 11:21 PM
MustangMatt96GT's Avatar
MustangMatt96GT
It could just be the gauge its self... my old one used to flutter. I got this isspro and it does not anymore...
Where is it tapped into and what type of gauge? What type of readings too?
Old Dec 7, 2009 | 12:00 AM
nelstone74's Avatar
nelstone74
my search ability just failed me, but I recalled some guys having the same problem and they fixed it by filling in the tee (just the guage leg) with JB weld and then dilling it out with a tiny bit and that dampened the flutter.
Old Dec 7, 2009 | 12:03 PM
yoslick's Avatar
yoslick
That works good or you can get a fish tank air line adjuster brass thingy and dial it closed to reduce the flutter as well.....
Old Dec 7, 2009 | 03:33 PM
Andy's250's Avatar
Andy's250
tell me more about this fish filter dial-o-matic outfit. i have the same problem. it has driven me crazy. about 14 or so on up it starts bouncing. tops out bouncing between 19-23.... very annoying i was thinking of making some type of hydraulic damper but that sounds much easier
Old Dec 7, 2009 | 05:12 PM
yoslick's Avatar
yoslick
I've seen em at the local pet/fish shops, they use em to run more than one tank off one compressor
Old Dec 7, 2009 | 06:45 PM
Andy's250's Avatar
Andy's250
thanks yoslick i'll have to check that out
Old Dec 7, 2009 | 07:25 PM
rivrrunner's Avatar
rivrrunner
this isspro gauge has been installed for 2 years and just recently started doing this...I have not looked at it but will this week.
With the performance issues wouldn't you think it was in the turbo itself?
Old Dec 8, 2009 | 08:47 AM
nelstone74's Avatar
nelstone74
you may be right, kinda got off track with the just the guage,
The easiest tthing to do first is to pull the intake hose off and inspect feel for play, look for dusting.
Old Dec 8, 2009 | 12:58 PM
Andy's250's Avatar
Andy's250
you might also check to make sure the boots from the turbo to the plenums are tight and the plenums arent leaking
Old Dec 8, 2009 | 02:29 PM
strokin'_tatsch's Avatar
strokin'_tatsch
inspect the turbo. check for play, dusting, the o-ring where the compressor outet meets the intake "Y", lower y boots. also check the map line to make sure there are no splits in it.
When you say performance issues how bad are we talking? How much boost is he building? excessive smoke?
Januch09
6.7L Power Stroke Diesel
Apr 29, 2016 04:56 PM
runner
Aug 19, 2015 11:41 AM
Enomra
Jul 29, 2008 10:22 PM
Brianut
Apr 28, 2008 07:59 PM
markshyd
Aug 31, 2001 07:17 PM
