A/C doesn't work(sometimes)
Old Dec 6, 2009 | 07:36 PM
lakewood's Avatar
lakewood
I have a 2005, 6.0 PSD, crew cab, Lariat, so it comes with the climate control A/C, not the reuglar one with the *****, this one you set the temp fan speed etc. and i can control it from buttons on the right-hand side of my steering wheel. About 3 months ago(back in August) i had those replaced bacause radio vol. contolled temp, temp controlled fan speed etc. and at the time i thought it had something to do with this ongoing problem that im having. The big problem is: the a/c doesn't work at all, nothing shows up on the digital screen, almost as if there's no power getting to it, luckily, it only does this rarely, last time it did it was around a month ago, and since i live in florida its hard to go without a/c, but luckily it's cold this week, Tomorrow it will work again, i know, When my A/C does go into this complete shut-down restarting the truck doesn't work, it just takes time at least an hour or more.... so any suggestions? I dont think flashing it will do anything, my truck got new batteries two months ago............
Old Dec 6, 2009 | 07:59 PM
Zmann's Avatar
Zmann
I'd be checking connectors and fuses for a bag connection
Old Dec 6, 2009 | 08:07 PM
lakewood's Avatar
lakewood
checked fuses, havent checked connectors
Old Dec 6, 2009 | 08:20 PM
cheezit's Avatar
cheezit
not uncommon to see control heads fail
Old Dec 6, 2009 | 08:38 PM
lakewood's Avatar
lakewood
not sure what a control head is...........
Old Dec 6, 2009 | 08:42 PM
cheezit's Avatar
cheezit
that would be the thing with the digital screen
Old Dec 6, 2009 | 08:58 PM
lakewood's Avatar
lakewood
ok, ha makes sense, i thought about that, ill check it out and see if i can find a used one, new one would probably take a chunk out of my wallet
Old Dec 6, 2009 | 09:18 PM
cheezit's Avatar
cheezit
Im not sure what they run but if I rember they droped in price. It may be worth a call to the local dealer.
Old Dec 7, 2009 | 08:42 AM
69cj's Avatar
69cj
With your engine running try turning your headlights on and off a couple of times. This has been known as a temporary fix. Buddy of mine has been doing that for a year now.
Old Dec 7, 2009 | 10:02 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I've had the same problem a couple of times.
I believe the culprit is called the EATC (Electronic Automatic Temperature Control) module.
Old Dec 7, 2009 | 03:45 PM
lakewood's Avatar
lakewood
CJ thanks, ill try that next time, steve how would i replace/fix the EATC
Old Dec 7, 2009 | 04:11 PM
SteveBricks
FTE Emeritus
I'm afraid I can't help you there....maybe someone knows of a thread that has that write-up. If there is one, I haven't found it.
Old Dec 7, 2009 | 07:33 PM
cheezit's Avatar
cheezit
the eatc is easy just pop the insterment bezel off and there are 4 7mm screws that hold it on. remove them and disconnect all the plugs on the back.
Old Dec 8, 2009 | 01:18 PM
delta70's Avatar
delta70
This happened to me once and this seemed to cure it for now at least. It has only happened once in the last 4 months so not sure it is really worth addressing any further at this point.
Old Dec 9, 2009 | 11:02 PM
JimBrazil's Avatar
JimBrazil
Happened to my '05 King Ranch today. I didn't know about the headlight reboot procedure but disconnecting the batteries for 5 minutes restarted the system.
JimB
rpf150man
2004 - 2008 F150
Jun 13, 2024 12:58 PM
jeff11
Aug 25, 2015 01:29 PM
troverman
Jul 31, 2015 06:37 AM
V8SHO
Jan 5, 2015 07:09 PM
granny_rocket
Dec 19, 2013 08:38 PM
