6.0 not starting
Old Dec 9, 2009 | 09:03 PM
shift6durastroke's Avatar
shift6durastroke
6.0 not starting
My pickup won't start after it's warm and it's starting hard when it's cold. Just got it going good tonight and I shut it off it wouldn't start up again. What is it? Please help
Old Dec 9, 2009 | 09:07 PM
cheezit's Avatar
cheezit
its a little hard with out know what year it is. what mods?
my guess would be you have a high pressure oil leak concern. can be stc fitting, block offs, stand pipes or ipr valve. do you have a code reader?
Old Dec 9, 2009 | 09:50 PM
shift6durastroke
It's a 2004 excursion with an 06 engine with an Elite high pressure fuel system and an egr delete kit. I have the throttle body still plugged in but it has an aftermarket elbow. Most of the electronics are from the 04 including the turbo. Although the IDM was built in 08 for the 06. It could be lots but I'm just out of ideas. No engine codes are popping up at all
Old Dec 9, 2009 | 10:35 PM
cheezit's Avatar
cheezit
ok sounds like a high pressure oil leak. can you moniter icp while cranking. I would suspect that you have a failed o-ring on a block off in the oil rail or a bad stc fitting.
Old Dec 9, 2009 | 11:08 PM
shift6durastroke
So that means engine back out. Sweet. Ialways wanted to do it twice in five days!!! And it's like 15 below freezing out.
