06 explorer blower motor problem (manual temp controls)
To kick off the coldest week (so far) of the winter season, I noticed a problem with the heater controls in my 06 Explorer with manual temp. controls. No matter which fan settings I select (defrost, panel+floor, etc), air does not blow through some of the vents. I can hear the fan working and air flows through the defrost vents and through the floor vents, but the there is no airflow through the vents below radio and round vents on the far left and far right sides of the dashboard.
Perhaps related to this problem, a couple months ago I replaced the blower motor resistor because fan speeds 1 and 2 did not work, only 3 and 4 worked, so whenever I would turn on the heat or A/C, it was on full blast all the time. After replacing the resistor, the issue was resolved and all of the speeds worked well. I guess I just never realized the issue with the vents, or maybe the problem happened because I replaced the resistor?
Since I'm not too knowledgeable with the climate control circuit, I'm not too sure where to begin, perhaps the switch or blower motor? Anyone else encounter a similar problem? I greatly appreciate any ideas in advance,
Happy New Year to everyone and thank you for your time!
