First off, I want to thank this board for saving me from getting ripped off by the dealer for $90 key. The programming was so simple that I wanted to go back in and laugh at the guy who cut the key. Now for the other question. I have a 1998 EB Expy. I would like to purchase a key FOB (which didn't come with the truck when I bought it new). I would like to know how do I tell if the truck is equipped with this option, and if so, how do I program the key fob that I plan to purchase to work with my truck??
1998 EB Expy
Completely Stock
Sony CDX-MP70 Head unit
Before you purchase a new key fob, you might want to check e-bay. I bought a replacement key fob there for about $10 for my 2001 Pontiac Montana (which I sold for my new '03 EB). Still was stuck with a $30 dealer programing--couldn't find any info on DIY.
Mine is a '99 EB Expy, so the instructions might vary slightly:
1 -- have ALL fobs on hand, including those which might already be programmed correctly. The programming will "erase" your old ones.
2 -- Unlock the doors. Put the key in the ignition, and turn from "Off" to "ACC" eight times in under 10 seconds. The doors will lock. Leave key in the ACC position
3 -- Program the fobs by pressing any key on the fob. Do this for each fob. The doors locks will lock/unlock
4 -- Turn the key to Off. Locks will lock/unlock, and you are out of programming mode.
5 -- Test all remotes.
6 -- With the money you have saved, take your spouse out to supper.
[updated:LAST EDITED ON 05-Aug-02 AT 04:06 PM (EST)]I've been watching e-bay and the fob for an expy must be quite rare. I assume it has to be an expy remote. Is this correct?
THANKS a lot to this board for this info. Origionally my truck came with one fob and set of keys. I got two new fobs on E-Bay for just $20. Just a day later the dealer found an extra set of keys to my truck and mailed them to me. Now I have two keys and four fobs. Regardless, I was able to program them all with the info provided here, and buy them cheap! Thanks a lot.
