distributor
Old Dec 6, 2009 | 03:19 PM
z1121jack's Avatar
z1121jack
distributor
I think I have the wrong distributor for my 351w. actually I have two old distributors and both have 1/4" holes for the oil pump shaft but the oil pump shaft is about a 5/16" as is the oil pump
How do you identify the 351w distributor .I know it is taller than other sb ford w's but I do not how much taller. Does it have a 5/16 hole in the bottom of the shaft?
Old Dec 6, 2009 | 09:14 PM
Conanski's Avatar
Conanski
Yes the 5.8 distributor has a larger hole for the oilpump shaft, the body where it goes into the block is also larger, but otherwise it will look pretty much the same.
rocfire
Jun 8, 2014 01:26 PM
Tyler S
Aug 6, 2013 03:30 PM
1982fordf100
Apr 25, 2006 02:43 PM
Racerdave
15
Mar 10, 2003 07:42 PM
