6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Power Steering whine
Old Dec 6, 2009 | 08:20 AM
KHH's Avatar
KHH
I have a Job 1 08 PSD with 21,000 mi. I've had zero problems for two years. Just yesterday, I noticed a whining noise that got louder when I turn the steering wheel. Guessing power steering problem. Anyone else experience this?
Old Dec 6, 2009 | 09:00 AM
ruschejj's Avatar
ruschejj
I think it's a sign of air in the system or a squeeky belt. Check both, turn the wheel lock to lock (in the dirt would be good) to try to purge air out. Watch the fluid level.
A bad pump would be a random thing and could happen to anybody.
Old Dec 6, 2009 | 09:37 AM
69cj's Avatar
69cj
If it does it consistatly take it to the dealer. You are still under the bumper to bumper warranty.
Old Dec 6, 2009 | 11:27 AM
koboss1's Avatar
koboss1
hey i had this same problem it was whinning so i checked the resivoir and it was just below the fill mark and i mean just below so check that and add even if you neew a little bit, i did and it took my noise away almost immediately i would almost think that they put the wrong fill mark on the tank.
Old Dec 6, 2009 | 12:04 PM
senix's Avatar
senix
x2 for checking the fluid level. Plus make sure it is full before you even take it in so that is eliminated in the dealers mind.
Old Dec 6, 2009 | 01:58 PM
KHH's Avatar
KHH
problem solved, Thanks
When I first checked the fluid, looked ok. After posting this, I rechecked, and the fluid was really foamy. I stirred it a bit, and it then was below the min. I added Merc ATF (as per owner's manual) and the whine went away. Thanks to all who replied.
Old Dec 6, 2009 | 08:17 PM
69cj's Avatar
69cj
So why are you all of a sudden low??
Old Dec 6, 2009 | 08:47 PM
KHH's Avatar
KHH
Good question. There was no apparent leaks or seepage. I am on Ford's extended service plan for severe conditions, and I've assumed they check all vital fluids. My dealership has a good reputation, and so far I've been very satisfied. Any ideas?
Old Dec 7, 2009 | 08:48 AM
69cj's Avatar
69cj
Do yourself and your truck a favor and always double check your fluids after they have had your truck.
Old Dec 7, 2009 | 10:19 AM
koboss1's Avatar
koboss1
I got on my creeper and looked everywhere under my truck and i couldnt find where mine dissapeared to either? all i found was a small leak around the crankshaft sensor that im not to worried about
koboss
sailorman3
Nov 5, 2016 08:22 AM
jim collins
Oct 29, 2016 09:36 PM
Cjohnson80
Jun 16, 2016 08:27 AM
customfoam
Nov 12, 2008 08:54 PM
mikedoughty
3.8 & 4.2L V6
Apr 7, 2006 07:51 AM
