High pressure fuel lines
Old Dec 6, 2009 | 12:33 AM
shift6durastroke's Avatar
shift6durastroke
I have high pressure fuel lines on my 2006 6.0 and there is a relay on my passenger side bolted to the alternator. there is a fitting comming out of the side of it and Im not sure where it goes or what goes in it. all other lines are accounted for and have a home......besides this fitting. help maybe?
Old Dec 6, 2009 | 12:38 AM
william_04_x's Avatar
william_04_x
Sounds unique(can you take a picture of it?).. The engine fuel supply lines on a stock system should run from the upper fuel bowl to the front of each head.. There are two other lines at the upper fuel bowl which are supply and return from the tank..
Old Dec 6, 2009 | 12:52 AM
shift6durastroke
Ya Ill take one tomorrow and put it on here. all of the lines from the stock bowl go to this regulator and then go to the heads. but there is a brass fitting on the side. WTF lol. When I get it figured out Im hoping there is no more problems with the excursion. all emmisions deleted!!
Old Dec 6, 2009 | 10:44 AM
william_04_x
Sounds like boost reference port on a pressure reg.. If so, you want to run some tubing from the port to below the motor, and vent it to atmosphere.. That's just a guess though.. The pic will be a great help..
Joes1Ton
Jan 9, 2013 01:21 PM
edzeb
Aug 3, 2012 08:02 AM
whitesdford
Dec 1, 2009 06:59 AM
ford141
15
Aug 27, 2007 06:58 PM
53fatfndr
Jul 4, 2004 01:49 AM
