Transmission removal
Old Dec 5, 2009 | 10:15 PM
andyman91's Avatar
andyman91
I removed a tranny on a 1969 dodge brougham motor home and it was not that difficult now my aod is going in my 1989 ford f150 and need to get it replaced i was wondering how and if you need to remove the engine to just so you can get the top bolts or is there a easy way.And do you have to get anything done to the drive shaft if you put a new tranny in.
Old Dec 6, 2009 | 02:33 AM
88n94's Avatar
88n94
Definitely shouldn't have to remove the engine. I'm betting if you lay under the truck and get good light by the top bolts, you'll find the bolts are easy to remove with the box end of a combination wrench.
Nothing would have to be done to the driveshaft if you are replacing with the same model transmission.
Old Dec 6, 2009 | 04:47 AM
jroehl's Avatar
jroehl
A bunch of extensions is all it takes to get those top two bolts from underneath the truck. Sometimes you can get them from above the engine compartment if you can reach in that far.
Jason
RM2738
6.4L Power Stroke Diesel
16
Jan 2, 2012 05:46 PM
Merculous
1997 - 2003 F150
Mar 24, 2005 09:41 PM
Merculous
Mar 16, 2005 04:21 PM
psf
Aerostar
Dec 26, 2004 03:32 PM
