Bolt/screw size
Old Dec 5, 2009 | 06:57 PM
Captain Obvious's Avatar
Captain Obvious
Bolt/screw size
85 Ford F150; am repacking the bearings on the front end.
Need a replacement stop screw on the outer hub body.
Need a cap screw (the external hex head bolt) for the outer cap.
Anyone know the dimensions for these fasteners? I am going to Fastenal to buy replacements this week.
Old Dec 5, 2009 | 09:32 PM
Franklin2's Avatar
Franklin2
I seem to remember the allen head bolt on the outside is a 10-32(thats a #10 screw with 32 threads per inch). You might have to take a good one to get the length and try different nuts on it to make sure of the size and thread. If you can't find one, you can take a regular round head 10-32 that takes a flat screwdriver, grind the outside of the head down a little bit, and it works well. I've had to drill several of the originals out when they get corroded and stuck.
Lukcv
Dec 30, 2011 09:06 PM
Nobby
Dec 18, 2011 09:16 PM
rich51fordtruck
Apr 12, 2009 06:48 PM
Deadeye1963
Jul 2, 2007 08:20 AM
AaronW
Oct 24, 2001 12:57 AM
