problems...
Old Dec 5, 2009 | 05:20 PM
JHoffman93's Avatar
JHoffman93
Sometimes batteries will appear fine when not under load but under heavy load they short out internally. I just had to replace mine, they ran lights, radio, glow plugs, etc. they even read almost 13 volts of charge just sitting there. As soon as you hit the key to start, lights dimmed and it would give about 1/4 of a revolution and quit. New batteries fixed the problem.
Old Dec 5, 2009 | 05:29 PM
starmilt's Avatar
starmilt
I've gotta go with dave on this one most of these rigs still have the original cables and they will start the truck years after they are bad without you really noticing it until you replace everything and you think wow this thing didn't spin this fast when it was new.
Bad batteries also make the starters wear out prematurly running on low voltage after awhile.
Old Dec 5, 2009 | 11:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
In the second post he made, the batteries were replaced a couple months ago.
I know that don't mean much with modern quality control, but it is enough for me to move them down the list to last place.
Batteries and cables that deliver less than full current to the starter do shorten it's life.
Cranks slow, so it is hard to start, which results in longer cranking times and more heat in the starter.
Heat is a big enemy in electric motors.
With new batteries, I am going to guess both the batteries and positive cable needs replaced.
Since both are on the expensive side, now the question is which is worse.
Does the starter have enough left that new cables can buy you a little time?
Or do the cables have enough left that they won't kill the new starter if you go the other way.
Old Dec 6, 2009 | 12:31 AM
onebadz's Avatar
onebadz
Okay fellas, sorry it took me so long to get back to you, I got the truck going and needed to do the work I had planned for the day. I jumped it vehicle to vehicle, my neighbors van to my passenger battery, after about 10 minutes of connection, I tried starting once WTS went out and it fired right up, quickly and smoothly. That was the best/easiest the truck has ever started. Obviously the blockwarmer worked last night because it should have been colder than hell if it didn't(it was 21 degrees when I finally got truck started) so what's your take on this? What could be causing my issues?
Old Dec 6, 2009 | 12:34 AM
onebadz's Avatar
onebadz
I also thought I'd add, I'm reasonably sure that the warmer worked too, because when the truck started, the truck didn't smoke like normal once started. Idk if this helps but figured I'd share everything.
Old Dec 6, 2009 | 12:35 AM
87crewdually's Avatar
87crewdually
Again, I'd pull the batts and get them load tested for the proper CCA's. Examine your batt cables for heat and corrosion.
Old Dec 6, 2009 | 08:25 PM
onebadz's Avatar
onebadz
Alright, will do.
Old Dec 6, 2009 | 10:07 PM
Dave Sponaugle
Look at the passenger side battery cable.
Pay close attention to the insulation near the battery clamp.
Does it look swollen, discolored or cracking brittle?
If so, then you have corrosion inside the cable and clamp.
The clamp and cable conductor are not making a good connection.
If the starter will crank, the resistance in the clamp will make the clamp hot under that much load.
A new cable is the only fix, those wires are to big to use any bolt on clamps for a repair.
New cables, minimum of 2/0 copper wire size, not tiny cable like you would find on a car.
If the battery terminals have not been cleaned recently, that is another location that could be causing problems.
They should have been cleaned when the new batteries were installed, but I have seen that step skipped at many auto parts stores.
Old Dec 6, 2009 | 10:10 PM
onebadz's Avatar
onebadz
You pretty much described to a T how the cable/connector looks. Ill look into getting one. Just any parts store have it in stock?
Old Dec 6, 2009 | 11:18 PM
Dave Sponaugle
Try NAPA, most of them can make cables.
Another place might be a large battery supplier, heavy truck dealer or heavy equipment dealer.
Most of the big trucks and heavy equipment use the flag connectors like the passenger side positive clamp since they have mulitple batteries.
Checker, Cragens, Autozone, Advance Auto and all those auto parts stores would be a waste of time.
Old Dec 6, 2009 | 11:30 PM
87crewdually
If you have time to wait here's the pos cable, or atleast this gives u the specs and measurements.
Ford Diesel Starter Cable 6.9 7.3:eBay Motors (item 170417136593 end time Dec-13-09 18:07:01 PST)
Old Dec 6, 2009 | 11:44 PM
Dave Sponaugle
That is not a bad price.
Last time I asked at Ford the price was in the 150 range.
Old Dec 6, 2009 | 11:47 PM
  #28
87crewdually
The only problem is it's an auction and no buy now. I'm watching it too see how high it goes.
Old Dec 7, 2009 | 04:17 AM
  #29
jhnlennon's Avatar
jhnlennon
Orileys has one, dont know if ya have near by, otherwise you could order it. Best price I have found so far, 75 bucks only, all 2/0 gauge too. Item Detail | O'Reilly Auto Parts
Old Dec 7, 2009 | 09:36 PM
  #30
Dave Sponaugle
There is a website I can't find ...custom battery cables or something like that that had them for sale for a reasonable price.
Not that cheap, but reasonable.
Several people in here used them and liked the quality.
I wish I could get all the information on my computer organized so I could find it when I need it.
I guess I just have to much stuff like site links saved.
