clunk when wheel is turned
Old Dec 5, 2009 | 09:03 AM
Mike821's Avatar
Mike821
Hello all....I though I read a post about clunking when the wheel is turned all the way at one point. I forget if this is just the way things are with a 4x4, but wanted to confirm. It happens when the wheel is truned either to the right or left at 90% and moving forward.
Also...what milage should I expect to replace ball joints? I have 88K on my truck. (light use) Just an estimate
Thanks all for your response in advance
Mike821
Old Dec 5, 2009 | 09:07 AM
barnbridge's Avatar
barnbridge
Not sure what the clunking is, could be many things, you need to do a good front end inspection. My ball joints needed replacing at 80,000 miles.
Old Dec 5, 2009 | 09:12 AM
bismic's Avatar
bismic
Mike821
Ball joints go out between 80 and 100k miles from what I have read (probably not what you wanted to hear).
You can check for play by jacking up the truck and seeing if each wheel moves when you apply some force to them (use your hands or you can put a lug wrench under the tire for the top-to-bottom check):
If each wheel moves top to bottom only, it is the ball joints.
If it moves in all directions then probably wheel bearings.
Sway bar (stabilizer bar) links go bad fairly often also. Check them out also.
Old Dec 5, 2009 | 09:29 AM
tex25025's Avatar
tex25025
I don't want to hear this either, I'm on borrowed time based on those averages. I didn't need to "hear" this, particularly with a road trip coming up in a week.
Old Dec 5, 2009 | 11:57 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If you get new BJ's get greasable ones. My uppers have 9/32 plugs that I unscrew and put a zerk in to grease them, then put the plug back in. Kinda a pain in the butt, but easier than replacing the BJs.
Old Dec 5, 2009 | 01:15 PM
Mike821's Avatar
Mike821
sounds like a low thud...thud..thud.....thud. Do you have any sound when you turn your wheel all the way to the right or left? (like making a U turn)
Thanks Bismic.....Yeah I am bracing for the yee ole ball joint job. I hear a great deal of people on the board do them rather than a dealer. What is the savings? How do you know they are shot? Anything to look for or listen for?
Old Dec 5, 2009 | 04:57 PM
johnnysF350's Avatar
johnnysF350
Your problem could also be a sticky hub. If you have the auto hubs and they have not been serviced or it's been a while they may not release causing the front U-Joint on that side of the axle to clunk on a tight turn. The front U-joints are also greasable and should be done periodically.
Old Dec 6, 2009 | 07:42 AM
Mike821's Avatar
Mike821
Thanks John....that brings up a good point. Have you ever done service on a set of hubs before? I do not know what the previous owner did, but I would be willing to DIY if it is not a real PIA.
Old Dec 6, 2009 | 07:53 AM
bismic's Avatar
bismic
[quote=bismic;8205810]You can check for play by jacking up the truck and seeing if each wheel moves when you apply some force to them (use your hands or you can put a lug wrench under the tire for the top-to-bottom check):
[quote]
Have you checked for "play" in the wheels yet?
Old Dec 6, 2009 | 08:24 AM
Mike821's Avatar
Mike821
LOL......I just looked for my jack. Seems that somone needed it and did not ruturn it. Once I get my jack back I will boost her up. I guess I can chance it with the stock jack...but you know how that is.
Tnx
Old Dec 6, 2009 | 09:43 AM
CombatMedicF-250's Avatar
CombatMedicF-250
TIM...I'm not gonna touch your reply with a ten foot pole!
It's all great info...and I've saved the page...but I'm laffing my @SS off here!
Sorry to hijack the thread!
Mike
Old Dec 6, 2009 | 06:48 PM
johnnysF350
I have not done them personally but many on this site have and it appears to be pretty easy... I believe there is info on how to do it in the tech folder. The reason I mentioned the hubs is that it happened to me on my '03 and I took it in to the dealer and they told me it was a sticky hub, they serviced it and the clunking went away. I had less than 10K on the truck when it happened.
