The problem has been intermitent but with a little patience, I could get them to go back up. However, they are now stuck down, three of them. It is not the switch, I am fairly certain b/c i can reach into the back seat or across the truck hitting other switches and same response, nothing happens. I have been trying to pattern the problem so i could have it fixed but everthing works perfectly fine in the truck, except this window issue. I figured it wasn't a fuse b/c with a fuse blown, it would not have been intermitent, it just would have stopped.
It could be a bad master window control switch because all the other switches for the windows ground through the master, this happend to me some time back on my 99 and my buddy who worked for Ford told me that they have seen this alot due to the ground contacts in the switch corroding, hopefully this helps
I have had some window trouble in my Expedition, not sticking down, but slamming up.
I believe that the problem is from water or windshield washer fluid getting into the door, I installed Ventshades, but the water still goes down in there. Not sure what to do now!
