three speed overdrive relay
Old Aug 10, 2003 | 07:12 PM
66fordf100's Avatar
66fordf100
I have a 66 F100 with three speed and overdrive. Can anyone show me where to find the overdrive relay so I can check the fuse? I am trying to find the reason the overdrive doesn't function. I am confident it is an electrical problem.
Thanks in advance for any advice concerning the overdrive system.
Old Aug 10, 2003 | 07:50 PM
banjopicker66's Avatar
banjopicker66
The overdrive relay is found on the firewall, just to the right of the master cylinder. It is between the master cylinder and the accelerator cable.
I have posted quite a bit on the Warner T-85N overdrive in this forum, and just posted again in the '67 - '72 forum.
Run a search for my name. banjopicker 66, and you will find more information.
Let me know if you have any more questions.
Old Aug 11, 2003 | 05:17 PM
66fordf100's Avatar
66fordf100
Thanks banjo. I will look the articles up and hopefully find all the info I need. Thanks again.
Ortarheel
18
Jan 28, 2024 01:44 PM
diharris
23
Mar 2, 2013 01:46 PM
jeffm66
May 22, 2010 03:33 PM
james G. phillips
16
Nov 30, 2007 06:54 PM
Ford Blue
Nov 8, 2004 04:45 PM
