2003 F-150 Front Hubs Don't Engage
Old 12-04-2009, 04:26 PM
mantta's Avatar
mantta
mantta is offline
Question 2003 F-150 Front Hubs Don't Engage
2003 F-150 Front hubs wil not engage in four wheel drive. The driveshaft turns, what should I look for?
Thanks!
Old 12-04-2009, 06:16 PM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
Take a look at the actuator on the front axle (under the plastic cover). Sometimes they get gummed up with road debris and crud. Also check to see if it's getting vacuum to the hoses.
Old 12-04-2009, 06:18 PM
mantta's Avatar
mantta
mantta is offline
Thanks Joe, Can you manually lock these hubs?
Thanks!
Old 12-04-2009, 10:34 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
when you put the **** in 4 wheel drive it does two things. first is electrical engage the transfer case to turn the drive shaft. second is the vacuum switch plunger in the front axle pulls in and ties the drive shaft to the axle. the half shafts and hubs are always connected together. they engage when the vacuum cylinder plunger moves in the pumpkin (axle), so no you can not manually engage or lock out the hubs.
66with352
1997 - 2003 F150
01-21-2017 05:43 AM
biz4two
2015 - 2020 F150
13
11-13-2016 06:26 PM
Rongold
1999 to 2016 Super Duty
13
11-24-2015 08:24 PM
Lee250
Bronco II
10-24-2008 06:44 PM
jimsford
Offroad & 4x4
12-27-2004 12:56 PM
Quick Reply: 2003 F-150 Front Hubs Don't Engage
