LMAO!
Old Dec 4, 2009 | 03:09 PM
wreckinball's Avatar
wreckinball
LMAO!
So i have essentially a straight run of pipe out the rear end. It has a large muffler on it and is really heavy at the end. I have tried three ways from sunday to get this secured in the back with two different kinds of mounting kits. I am sick of this crap and need it gone. I dont want it to be ridiculous loud but if it means i can have it slash cut out the passenger side in front of the tire i will accept a little noise. Can i use a modified thrush style muffler or something smaller? The one on weighs too damn much and is like a gas tank size. hahaha. I have pondered stacks but i transport hay for the ponies too often and the wife would never let me live that one down! haha. Thoughts on a reroute? Can i do it without a welder? You can just barely make it out above left of my diff in this pic and you can see the long *** pipe out the back. Today i backed into a fence post(windows were too frosty and i thought i knew where i was! hahaha. Well it stick out past the bumper for some odd reason and it popped the last hanger i installed. So i am done with it!!!!!!
Old Dec 4, 2009 | 03:24 PM
starmilt's Avatar
starmilt
Hard to make out in the pic but looks like rhe factory muffler. Are you running a turbo.
Old Dec 4, 2009 | 03:27 PM
starmilt's Avatar
starmilt
Ok should of read your sig first.
If it was me I would eventually go with a set of true duals, you will be suprized at the performance difference.
Old Dec 4, 2009 | 03:30 PM
bill11012's Avatar
bill11012
Modular motor junkie
I have a real small glass pack on mine that I have never had a problem with.
It stops before the back axle and the tip points down.
Old Dec 4, 2009 | 03:31 PM
wreckinball
Haha yeah I appears factory. No turbo and that is what I hear you need to eliminate mufflers
Old Dec 4, 2009 | 03:51 PM
starmilt's Avatar
starmilt
You eliminate the mufflers without a turbo, your neighbors are not going to like you anymore.
Old Dec 4, 2009 | 04:31 PM
wreckinball
Even without turbo?
Old Dec 4, 2009 | 04:35 PM
starmilt's Avatar
starmilt
The turbo chopps up the exhaust and they are very livable without a muffler.
Straight pipes without a turbo are LOUD especially when towing a load.
Old Dec 4, 2009 | 04:47 PM
dyoung14's Avatar
dyoung14
if you run a straihgt pipe all the way out the back it wont be loud in the cab, but if you live somewere were you can get a ticket for a loud truck then dont do this, but you will love the sound of a super 44 flowmaster, or at least i do, here watch this video at the end i rev it up for an exhuast sound its not a long video
YouTube - MY BUDDY'S 1986 6.9 HOTT ROD
Old Dec 4, 2009 | 05:27 PM
bill11012's Avatar
bill11012
nice, how much is the pump turned up?
Old Dec 4, 2009 | 08:12 PM
wreckinball
Well it is not necessarily straight pipes that i want, i would like to have the setup i currently have and chop it down with a smaller muffler or glasspack. Then i want to angle it at about 22.5-45 coming out prior to the passenger rear tire. I know one day i would like a turbo but for the price i have no justification.
Old Dec 4, 2009 | 08:56 PM
starmilt's Avatar
starmilt
Go wiyh duals off the manifolds and 2 smaller mufflers and it will be like driving another truck. Factory exhaust chokes these down terribly.
Old Dec 4, 2009 | 09:22 PM
dyoung14's Avatar
dyoung14
1.5 flats, it just smokes a slight haze after 3500, and after 4000 smoke is gone, but at low rpm i rolls the black, i run out of fuel at high rpm cause the pump timing curve cannot keep up
Old Dec 4, 2009 | 10:30 PM
wreckinball
I will see what i can find, is it a substantial hp gain?
Old Dec 5, 2009 | 12:46 AM
starmilt's Avatar
starmilt
Well I have run the stock exhaust, dual straights dual with mufflers all na.
As far as hp increase I can't give you any numbers but the but dyno feels like a good torque gain especially low end. I have had more low end torque with a na than my regular driver with turbo.
mstiles19
The Next Generation
Nov 17, 2012 11:40 AM
redrivergorge
Jan 25, 2011 07:22 PM
wreckinball
Jan 7, 2010 03:04 AM
blue beast
26
Mar 14, 2008 06:36 PM
GHog
May 30, 2005 07:41 AM
