injection pump lines
Old Dec 3, 2009 | 08:26 PM
fixitman1310's Avatar
fixitman1310
hey guys can the injector lines be replaced without removing the
injector pump. is there a tool for this. i have one line on the bottom
of the pump that needs replaced. it was leaking out of the nut
where it bolts to the injector. thanks alot
fixitman4710@hotmail.com steve
Old Dec 3, 2009 | 08:31 PM
wreckinball's Avatar
wreckinball
depends on where it is, sometimes they are hard to get on the bottom, i have heard of making a tool to fit but never saw one in person. It can be done so far as i know.
Old Dec 3, 2009 | 08:34 PM
dyoung14's Avatar
dyoung14
personally i would pull the ip, but i have done a bunch so its easy for me now, i can have an ip swapped in about 30 minutes
Old Dec 3, 2009 | 09:41 PM
9473's Avatar
9473
Dang Doug, it takes me almost that long to crawl up in there. LOL. I lost a line in south Texas once a did a stay over at a campground until it was delivered. I didn't remove the pump but had to remove a few lines to get to the bad one.
Old Dec 3, 2009 | 11:17 PM
Coolball's Avatar
Coolball
Somebody please put some info up about this mystery tool. Have a line on the bottom that is a little wet and would like to tighten it up without pulling all the lines.
Old Dec 3, 2009 | 11:36 PM
9473's Avatar
9473
I maybe wrong but I think the tool referred to is an odd angled open end box wrench. It may be one thing to detach the line but getting it back on you'll need adequate access to seat it properly.
Old Dec 4, 2009 | 12:21 AM
Coolball's Avatar
Coolball
Yep just want to give the bottom one a half turn not worth taking all the other ones off though lol
Old Dec 4, 2009 | 07:41 AM
7bicks's Avatar
7bicks
Basically it is a build your own type wrench. Get a cheap one and cut and weld or heat and bend it to a shape that will allow you to reach the desired line. It will look like a horse shoe with one long extended end and will be fairly short on the open end side when you are done.
Old Dec 4, 2009 | 07:50 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
I like these.
http://www.toolspot.co.uk/product/dr...ot-spanner-set
Old Dec 4, 2009 | 12:57 PM
starmilt's Avatar
starmilt
They also make those crowfoot wrenches kike a 12 point box end with a cutout, they work a little better in tight spots.
Old Dec 4, 2009 | 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Look at these.
Martin Tool & Forge 11 Pc. 15 and 60 Degree Angle Head Wrench Set
They also make another set with 80 degree offset on one end.
Vim Products 11 Piece Miniature Angle Wrench Set
I just show those as examples, did not even look to see if they were SAE or Metric.
Old Dec 5, 2009 | 10:41 AM
9473's Avatar
9473
Originally Posted by Dave Sponaugle
Look at these.
I had access to shop tools when I did my pump. The wrenches were offset but I don't recall the angle. They may have even been the S type. I think I'll check what I need for size and go to Sears for a few configurations. I would go with Snap-on's but that money needs to go for the pump and injectors. lol
fixitman4710
21
Jul 29, 2014 01:00 AM
fixitman1310
May 1, 2010 12:08 PM
fixitman1310
13
Mar 3, 2010 09:18 PM
fixitman1310
Feb 27, 2010 08:18 PM
fixitman1310
Feb 14, 2010 08:24 PM
