Where to find a Power steering pulley
Hello everybody Looking for a Power steering Pulley for a 1975 Ford F150 A/T 360 2wd I was replacing my power steering pump and at the time didn't have a pulley puller so I was trying to remove it with another type of puller and that didn't go well I damage the pulley and now its bent I put in the pump and that doesn't leak anymore but now the belt doesn't stay on because the pulley is bent other than going to the junkyard is there any autopart store that stock these pulley's.
on
1 Post
did the same thing with my 76. took 10 minutes to set everything up and get it off the old pump. put it on the new pump using a rubber mallet as close to the center as possible. my suggestion for once its on the shaft, use a peice of pipe between the mallet and pulley that will go over the shaft to apply even pressure while you tap it back on.
Drlittle
06-05-2017 11:34 PM
mxer0022
09-13-2016 09:58 PM
henryfrick
05-22-2016 05:26 PM
