1947 truck
Old Dec 17, 2009 | 08:12 PM
havi's Avatar
havi
I'll have the Roast Duck
FOW, Any more pics of the frame you posted? I'm just trying to compare the '47 frame with the '48-52's.
Old Dec 17, 2009 | 08:23 PM
Fighter-of-Wars's Avatar
Fighter-of-Wars
If you want I can take more pics if needed. FYI this is a longbed chassis.
Old Dec 17, 2009 | 08:25 PM
havi's Avatar
havi
Thanks, any of the front half?
Old Dec 17, 2009 | 08:36 PM
Fighter-of-Wars
I've got a couple of when the truck was still on it, I will try and get some tommorow.
Old Dec 17, 2009 | 08:50 PM
havi's Avatar
havi
No hurry at all. Just that I may end up with an extra '48 F1 frame, so I pondered finding a '42-47 body to put on it. I heard they were about the same. But wanted to be sure before going on a body search.
Old Dec 17, 2009 | 09:08 PM
soule46's Avatar
soule46
Havi, The frame posted is a bigger truck frame. Primarily the springs and length are different from the 1/2 ton '42-'47.
I posted a few picts of my 1/2 ton frame in this post you get a better pict of the front of the frame and I have some dimensions as well:
https://www.ford-trucks.com/forums/7...ame-specs.html
The '48 actually extends longer past the front cross beam. If I recall correctly the shackles on the front springs are on the front of the spring on the '48 as well (but that shouldn't affect what you are planning.
Old Dec 17, 2009 | 09:17 PM
havi's Avatar
havi
Yeah, the F1 frame's front springs front (say that fast 3 times) is inside the frame through a sleeve. Here's a quick pic. Cutting the front rails off wouldn't be a problem, and leave the springs like the '48. perhaps?
Old Dec 17, 2009 | 09:54 PM
soule46's Avatar
soule46
Springs should be fine, the springs themselves are the same, just the mounting is different and shouldn't matter, the front axle is actually a better one to start with -- the '47 used lever shocks (I can never spell the real name :-). The '48 axle therefore has some extra material on the bottom where the tube shock mounts to. From your pict the '48 looks like it has the same arc over the front axle. The front cab mount (right above the rear front spring hanger) looks the same and in about the same spot. The second cab mount on your pict looks bigger, mine only has one hole and doesn't have the extra vertical support. My guess is that it wouldn't be too hard at all to put the older sheetmetal on the '48 frame.
Old Dec 18, 2009 | 08:52 AM
COMPLIT1107's Avatar
COMPLIT1107
Here's some close-ups of the 47 frame. I had already pulled the front end (going to IFS) but it shows the spring perches and shape of the front.
Rear perches and Tranny x-member
Nothing was trimmed or cut off. The front perches are end the end of the frame.
bmfox
Modular V10 (6.8l)
19
Mar 23, 2017 04:08 PM
willowbilly3
1947 and Older Ford Trucks
Sep 27, 2015 08:09 PM
DmanNC
May 25, 2014 09:11 PM
johnson2007
26
Sep 24, 2011 01:25 AM
krewat
Modular V10 (6.8l)
Sep 20, 2010 06:00 PM
