1947 truck
Old Dec 2, 2009 | 03:59 PM
Griff52's Avatar
Griff52
Question 1947 truck
Hi all, I think my '47 may be a bit older. The only numbers I could find were on the bell housing by tranny..it has a star then99T-48952 then a star, oil filler cap is up next to fire wall,distributor is crab style. I have posted some phots also,let me know what you think thanks.
Old Dec 2, 2009 | 08:06 PM
Fighter-of-Wars's Avatar
Fighter-of-Wars
There should be a number before the "99T" that states the year. The best place to look is on the frame by the power steering box. Here is a pic of the location. And a site to decode the numbers. 1947 Ford Truck US* Canadian Mer
Last edited by Fighter-of-Wars; Dec 3, 2009 at 10:12 PM. Reason: Done some reseaching and "T" does mean its a truck
Old Dec 3, 2009 | 05:32 AM
Griff52's Avatar
Griff52
Thanks you have been a great help,handy having a spare frame around also. If it stops raining I'll go looking. Stoped raining so I went looking,found same number on frame beside the steering box. could the stars mean it was military? Checked this site vanpeltsales.com and found out ford did use the stars before and after the srial no. so no one could add a number later,99T is code for 1939 1-1/2 ton truck (at least that was when it was made) Could my cab come off a newer truck maybe?
Old Dec 3, 2009 | 04:34 PM
46fordtruck's Avatar
46fordtruck
Going by the serial number, you have a '45 truck, don't worry about the 99T thing, Ford used that for years.
Old Dec 3, 2009 | 10:21 PM
Fighter-of-Wars
I'm starting to get confused here. I always thought there should be 3 numbers then a letter to tell the year, engine, and weight class. But since you can only find 2 numbers and a letter, I don't know what to think. Here is a pic of my serial number and what I call the "class number" (number that tells what class, engine. etc the truck is) Sorry for the big pics but the numbers are hard to read. I don't think the starts mean its military either, this is just a 1 ton truck from 1947 with, if I remember right, a 122" wheelbase.
Old Dec 4, 2009 | 02:22 PM
46fordtruck
The VIN always had a star, has nothing to do with military. It was Ford's way to make sure nobody could had numbers or letters to the serial number. When you would fregister the vehicle the VIN would start 799Y and be followed by the numbers. So the number issued by ford would be 799Y1982588. 7 being year, 99 being V8 engine, Y being 1 ton truck. In the case of the 99T, at that time the serial number did not tell year, just that it was the 100 HP V8 in a 1.5 ton chassis.
Old Dec 7, 2009 | 12:22 PM
Griff52's Avatar
Griff52
I was checking under dash for wiper moter and noticed that there was a cowl vent under there some one had put body filler over it to hide it from the out side. Any idea what year they stoped the cowl vent?
And thanks for all info and your time
Old Dec 7, 2009 | 06:38 PM
COMPLIT1107's Avatar
COMPLIT1107
Cowl Vents went to at least 1956.
Old Dec 7, 2009 | 07:38 PM
soule46's Avatar
soule46
Gary, the 239 CI V8 started in the Mercs in '39. I have heard that some of the bigger trucks like the the 1.5 ton could have the early 239 in them. Have you ever seen one or heard of this? They would then have the 99T- with the lower SN found in the very early ones, right?
Old Dec 7, 2009 | 08:00 PM
46fordtruck
Yes, the Merc V8 was optional up until the '45 when the 100 HP Merc V8 became the standard V8. For instance, in '42 Ford ads stated "choice of two V8's" you could get either the 221 CI 90 HP Ford V8 or the 239 CI 100 HP V8.
Old Dec 8, 2009 | 03:17 PM
Griff52's Avatar
Griff52
Just got the registration from the guy I bought the truck from,another set of numbers Vin # D236684F242,I can not find this number any place on the cab,not even close to the numbers on the frame. Cab and running gear pieced togather?
Old Dec 8, 2009 | 03:27 PM
46fordtruck
That is not a Ford VIN, chances are it's a state issude VIN number. Does not necessarily mean a pieced together truck, either they could not find the original VIN on the truck and it was issued a replacement VIN, it could have been a salvage. If that number is on the paperwork, then you can just keep it. Might be less hassle to just leave that number, depending on your state.
I noticed earlier you were wondering if it's a '39, I'll give you a simple way to know if it's a '39 frame or not. Get under the front of the truck, look at the front axle, if it only has one spring pack and a radius rod set up, it's a '39, if it has dual parallel leaf springs, and no radius rod (wishbone) set up, it is not a '39 frame.
Old Dec 8, 2009 | 03:38 PM
Griff52's Avatar
Griff52
Thanks you guys are a real help.
Vern in Casco ME
Old Dec 8, 2009 | 03:55 PM
soule46's Avatar
soule46
Look More for an add on tag somewhere on the frame. Usually a State issued VIN will have a tag with it that should have been attached to the frame or cab.
Old Dec 16, 2009 | 09:12 AM
Griff52's Avatar
Griff52
I was checking info on western New York Early Ford V-8 club they had my serial number as late '42 so I guess that and my engine set up every thing points to my '47 being a '42. I got more for my money
Vern
