I am trying to bolt my new driveshaft up on my truck finaly. I have the problem of the T19 2wd being a smaller U-joint that the driveshaft. Will the D50 TTB yoke bolt up to the T19? I am thinking if I remove both yokes and put the bigger one on the trans that I can make this work untill I can swap the 4wd T19 in.
Why they make ujoints that are different size on side to the other, if you have a decent parts man that will work with you he can find you one that fits. This is something that I have done several times.
Ok I gotcha. I will take a look at my local store tomorrow.
You have a two piece driveshaft?
Does it have a slip yoke on the tranny or does the U joint bolt to a fixed joint and it has a slip joint in the drive shaft?
If fixed yoke, measure the cap diameter and cross length and take that info with you.
