temp control
Old Dec 2, 2009 | 03:02 PM
97oneton's Avatar
97oneton
temp control
i got a 96 and the temp control door wont swing back and forth or right to left whichever you prefer.the cable moves on the switch end and the door end,everything moves but the door.it is stuck on the cool setting the door is.can i replace the door?anybody else had/have this problem or know how to fix it?thanks
Old Dec 2, 2009 | 07:08 PM
fmr9's Avatar
fmr9
Replacing the door is not an easy job, and may not be necessary.
It is pretty common for smal articles to fall down thru the defrost vents and end up in the door path. Persoanlly I found a 3 inch deck screw in mine, but had heard of a wide variety of things stuck in the door.
It will only take a few minutes to remove the glovebox and then the heater core cover. The blend door is then visible in the lower left corner.
Good Luck Frank
Old Dec 2, 2009 | 07:11 PM
truckrider814's Avatar
truckrider814
I have a similar problem with mine except i know that im missing parts to the door. soo i figured I'd subscribe to the tread.
Kyle
Old Dec 6, 2009 | 08:02 PM
97oneton's Avatar
97oneton
Good Luck Frank
about half of a #2 pencil blocking the door
Old Dec 6, 2009 | 09:45 PM
fmr9's Avatar
fmr9
Glad it worked out for you. Changing the door is not a fun job.
Frank
Old Dec 7, 2009 | 06:20 AM
truckrider814
so i guess im the only lucky one who actually needs to replace parts in there. haha
Kyle
Old Dec 7, 2009 | 08:59 AM
fmr9's Avatar
fmr9
Kyle
Might want to look at alternatives. When I got my truck, the heater output all went to the defrost vents. Found out the arm was broken at the diverter flap. This is not the same as the blend door, but similar. I looked at what had to come apart to replace this flap, and it was not an easy fix. I managed to shoot a small self tapping screw into the flap, and attach a cable. Used a cable like the old manual choke, or like throttle cable on a lawnmower. This allowed me to push the door up, for heat to the floor, or pull it down to divert flow to defrost. It ain't factory, or very convient, but it works.
I usually leave it about 1/2way, unless the windshield is getting piled up with snow.
You may be able to do something similar to control your broken blend door.
Think outside the box.
Good Luck
Frank
Hoever
New Member Introductions
Jan 1, 2015 01:07 AM
Nate68
Nov 12, 2013 11:06 PM
speedracer2012
1997 - 2003 F150
Nov 11, 2012 05:41 PM
hofmeyer
Jan 18, 2006 12:04 PM
