1978 - 1996 Big Bronco
Transmission Swap
Old Dec 2, 2009 | 11:39 AM
Surf Fishn Truck's Avatar
Surf Fishn Truck
Transmission Swap
Can you switch the 1989 C6 with a 1989 E40D transmission without any other issues? I have just inherited an 89 Bronco XLT.
Old Dec 2, 2009 | 01:15 PM
DLP Performance's Avatar
DLP Performance
No. It CAN be done, but the juice won't be worth the squeeze. It might pay for itself in gas mileage after 100k miles.
An AOD swap would be a worthwhile venture, but it won't be quite as strong as the C6. I think you could even reuse the driveshafts.
Old Dec 2, 2009 | 01:25 PM
85e150's Avatar
85e150
You can read specs and propaganda here on this 4x4 beefed AOD to get an idea or two on the AOD conversion. This is still cheaper than a new Gear Vendors set up, and cheaper than an E4OD, which would also require a $500+ controller on top of the trans:
TCI Auto: AOD StreetFighter® Transmission 4X4
Old Dec 2, 2009 | 01:28 PM
helirich's Avatar
helirich
An AOD is 9" shorter than a E40D. The driveshafts are very differnt and of course the mount location in your frame. I dont know about the differnce between a C6 and the E40D.
Old Dec 2, 2009 | 01:33 PM
85e150's Avatar
85e150
According to this:
TCI - TECHNICAL INFORMATION: Transmission Dimensions
C6: 33 1/2
AOD: 30 3/8
Not sure if this is correct for 4x4 model transmissions.
Old Dec 2, 2009 | 03:13 PM
alxsnmr's Avatar
alxsnmr
It wasnt specific if that deminsion was for the 4x4 or the 4x2 trans, but the 4x4 C-6 is something like 8 inches shorter than the 4x4 E4OD. An inch of difference I would think the driveshafts could handle b/w the AOD and C-6, but why would you want to go to a the early E4OD with its known problems just for gas mileage? A good tune-up can get you within a mpg of the E4OD mpg on that C-6 unless it is slipping terribly.
Old Dec 2, 2009 | 06:44 PM
greystreak92's Avatar
greystreak92
Rebuild the C6 or make the AOD swap. You don't want an E4OD from that model year anyway even if you did spend all that extra money for no reason. The E4OD is by far the longest (physical dimension), most expensive, and most difficult to install of the three units. Given that the E4OD requires a separate controller in any vehicle that wasn't originally equipped with it so that it will "know" when to shift, its just a lot of time, money and effort that isn't really necessary.
Old Dec 2, 2009 | 09:45 PM
helirich's Avatar
helirich
I wasnt sure which way he was switching. I think the highway millage would be consideratly better with OD. I would agree with Greystreak, C6 or AOD unless it has a E40D allready.
Old Dec 3, 2009 | 10:31 AM
Kemicalburns's Avatar
Kemicalburns
if you swap to an AOD you will need to purchase a new flexplate for an 88-89 crownvictoria with a 5.8/AOD. reason being is the 5.8 was never bolted to an AOD from the factory in a bronco or f150. to bad your in Virgina as i have an AOD with the proper 5.8 flex plate for sale but im in Oregon and shipping would be a killer.
Old Dec 3, 2009 | 08:05 PM
helirich's Avatar
helirich
Kem,
When you say flex plate, do you mean the part the Torque converter bolts to?
Old Dec 4, 2009 | 10:41 AM
Kemicalburns
yes. a flywheel being for a manual tranny and the flexplate for an auto tranny.
if you want to run the 5.8 in front of an AOD you would need this flexplate from a car.
Old Dec 5, 2009 | 11:50 AM
DLP Performance
Why would you need to change the flywheel? Aren't they both 164 tooth w/ the same bolt pattern? I've gone from C4 to C6 or AOD a few times & never had a problem. I had a problem with an older C4 once. I got a bellhousing for a Windsor w/ 164 tooth flywheel, but I was running a 157 tooth on a 302. I had to swap the bellhousing so the starter would engage.
kvillecomet
Apr 22, 2009 08:58 PM
jlh
Jan 22, 2004 06:08 PM
TheBlackRhombus
Jun 30, 2003 09:42 PM
strong74
Jan 14, 2003 06:11 AM
