electronic flasher
Old Dec 3, 2009 | 07:25 AM
just another truck's Avatar
just another truck
First, I would check the fuse, I would then look again at the relay. The thing that has me confused is the Brake lights, but otherwise I would start looking at teh turn signal/hazard lights switch in the coloumn.
How decent are you with electrical prints? I ask this, because what we can do is I send you what I have ( email) in prints and then either tonight ( between 4 and 6, I have school after 6), or tomorrow night (between 4 and I think 7, nieces birthday party after 7), or even saturday, ( I am good here from 7 am till noon, even later if needed, but I have homework I have to try and wrap up ) we can both be looking at the prints, and try a couple different test until we see something.
Old Dec 3, 2009 | 11:20 AM
travisp_95's Avatar
travisp_95
Unhappy
well the lights worked after i instaled the new relay. so i thought every thing is good then this morning no lights.
Old Dec 4, 2009 | 07:07 AM
travisp_95's Avatar
travisp_95
hey just another truck could you send me what wiring diagrams you have to me over email mine is travisp_95@yahoo.com thanks
Old Dec 4, 2009 | 01:04 PM
just another truck
SOrry I missed this earlier, been a tad busy, but check your email, should be there any minute!
Old Dec 6, 2009 | 10:33 PM
travisp_95's Avatar
travisp_95
Pat thanks for the diagrams helped a lot found problem. Wasn't the electronic flasher. The plug on the mutifunction switch was comeing out when i tilted the stering wheel. so i got it fixed.
Thanks Travis
Old Dec 6, 2009 | 11:44 PM
firedewd's Avatar
firedewd
Welcome to FTE. Glad you found the problem and thanks for getting back to us with the resolution. You may have helped many others in the future!!
Cheers!
Old Jan 30, 2010 | 06:26 PM
mattinco's Avatar
mattinco
Turn/hazard relay 1999 F350
Originally Posted by clintbonnie
That is one thing FORD could have done a better job on, locating a easier place for the those flashers !!
And a Big Welcome Travis to our forum..
Just got done replacing one (1) of the two (2) flasher relays (the one closest to the firewall) in my 1999 F350; all's well so far. To add some detail to your already helpful pointers; 1) my aftermarket Pioneer in-dash came with "keys" for removing the radio (though not the mounting bracket, which I removed after bending the securing tabs inward), the surrounding plastic got a bit roughed up; 2) to shorten the length of time fishing for the pair of side-by-side relays, mine were sortakinda suspended in mid-air, down and to the left ("elbow deep") of the radio opening, and covered with a black plastic housing (approximatedly 1.5 in. by 2.25 in.; pinch the sides HARD and it will pop off); 3) the new, and LARGER than standard, relay from NAPA does not allow the cover to be replaced afterward (my replacement did in fact say "heavy duty"), which inspires some confidence that it may actually last while powering an extra set of stop/turn/flasher light high up on the headache rack, and towing a trailer; 4) my Haines manual did show a picture of where the relays "should" have been (to the right of steering column), but was not accurate for my individual vehicle. Now I can stop scaring the bejeesus out of people that don't know I'm making a move!
gpeade
2004 - 2008 F150
Dec 12, 2015 09:20 AM
79BRNC
Sep 21, 2011 10:43 AM
BigBlueMacDaddy
Electrical Systems/Wiring
Aug 3, 2011 11:32 PM
scott_z
Jun 18, 2010 01:34 PM
Expedition Mom
Apr 11, 2010 01:33 PM
