where is the electronic flasher relay or moduel on a 99 f250 super duty? any help would be great. I don't have turn signals or flashers or brake lights.
Thanks Travis
The flasher relays are a bit fun to get to, you have to remove the stero, pay the 5.00 for the stero removal kit from auto zone, all I did was scratch thing when using the coat hanger. You will see them on the left, almost elbow deep. The flasher relays ( if I remeber correcdtly) come in a set.
That is one thing FORD could have done a better job on, locating a easier place for the those flashers !!
Man,,,I am glad you posted this.I did not have a clue where they were..Thanks
Welcome Travis,you will get fixed up here
well her is a little bit bout my truck. I bought it nov. 29 09. then tuesday i didn't have turn signals, haz, or brake lights. but that is my luck. it is a e99 f250 ex cab long bed 7.3 i think it has a 4" exhaust but not sure what else it has performance wise. it has a brush gaurd and a different rear bumper.
Thanks Travis
This is a dumb question, but do you have front flashers?
well here is the good and bad news..... GOOD NEWS I found the turn signal relay it is behind the radio changed it and worked just fine. BAAAAD NEWS get in it this morning and no turn,haz,or brake lights. the only thing i did after i changed the relay is plug in the block heater and then remote start this morning. So What the F*%$
