I-Beam Flip?
Old Dec 1, 2009 | 09:53 PM
Sayer Lane's Avatar
Sayer Lane
I-Beam Flip?
Hey guys I've got a 2wd and i'd like to lift it. One of my buddies said his cousin flipped his 2wd's I-Beam and it lifted it quite a bit. I just wanted to see if anybody had done it, or knows what i am talking about.
Old Dec 2, 2009 | 01:28 AM
75F350's Avatar
75F350
Just speculating and thinking out loud here, but the caster is built into the end of the beam, and it seems that flipping this would cause quite the stir with the king pin angle.
Isnt that why most desert guys are bending beams?
Old Dec 2, 2009 | 07:41 AM
northeaster79's Avatar
northeaster79
I'm with F350 on that one,I would't do that unless it was just going to be an offroad pounder.
Old Dec 2, 2009 | 08:18 AM
Broncoholic1's Avatar
Broncoholic1
Flip it heat it up & bend it. Instant Pre-Runner
Old Dec 2, 2009 | 12:00 PM
ChaseTruck754's Avatar
ChaseTruck754
Yup.
If only it was that easy
This has been covered before and people do it. A search will come up with a thread or 2 with more info and pics.
Old Dec 2, 2009 | 02:44 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
I beam flip
Check for the I-beams on a Econoline Van, if I remember right the ends are straighter and would give some lift over a truck I beam. I checked into this years ago when I wanted to make a prerunner looking 2wd.
Old Dec 2, 2009 | 02:49 PM
ChaseTruck754
yes - SOME of the E series vans had straighter ends on the beams. I don't know if they can be just bolted in to attain lift though. Never heard of anybody doing that.
Old Jan 13, 2010 | 09:00 PM
93F22A6's Avatar
93F22A6
I would like to know if anybody has tried this. I want to lift my truck, and this would be cheaper than the 700 autfab lift. Also where and how much does it cost to get an i beam bent?
Old Jan 14, 2010 | 08:30 PM
ChaseTruck754
search this topic. There was another thread about it that had pics, etc.
Try hitting up local big rig shops and see if they bend i-beam front ends to correct alignment (camber). Older trucks (big and small) had i-beam front ends and often big rig type shops are very used to aligning trucks like this.
Old Jan 15, 2010 | 03:10 PM
bubbasinafordf150's Avatar
bubbasinafordf150
email me a ford_boyzelite@yahoo.com i have some pics that i saved from looking threw the post for the same thing, it would be alot better to build 3 inch drop brackets and throw 3/4 ton econoline springs outta a mid 80s e250 van or 350 van in it, or do the beam flip and swap driver and passenger sides and take it to a shop and get it aligned and let us all know how far out the shop said.
Old Jan 15, 2010 | 04:51 PM
ChaseTruck754
Originally Posted by bubbasinafordf150
email me a ford_boyzelite@yahoo.com i have some pics that i saved from looking threw the post for the same thing, it would be alot cheaper to build 3 inch drop brackets and throw 3/4 ton econoline springs outta a mid 80s e250 van or 350 van in it, or do the beam flip and swap driver and passenger sides and take it to a shop and get it aligned and let us all know how far out the shop said.
Fixed that for you as "better" was not the correct word
Old Jan 15, 2010 | 05:07 PM
Sayer Lane's Avatar
Sayer Lane
Sorry to inform you guys that i won't be doing this as a project on my truck anymore. Since I had posted this i found some tires and rims and decided i didnt want i lift that much anymore but keep this thread going for all the other guys wanting a 2-wheel drive lifted.
--Sayer
Old Jan 15, 2010 | 06:06 PM
bubbasinafordf150
thanks man. guess i need reread what i type lol
Old Jan 19, 2010 | 08:44 PM
93F22A6's Avatar
93F22A6
So if you swaped sides it should be ok as far as caster goes. Also what is the stock camber spec. If it's sero then you should'nt even have to align the truck (it's what I'm praying for). Drop brackets seem like a good idea, but would I need to lengthen the radius arms.
Old Jan 20, 2010 | 10:28 PM
NUTTY4X4's Avatar
NUTTY4X4
why dont you just straight axle ? even though why would you lift a 2wd its like lowering a 4wd
