Stancor GPR's
Old Dec 1, 2009 | 08:30 AM
onelionhunter's Avatar
onelionhunter
Stancor GPR's
I ordered 2 of the Stancor GPR replacements for my buddies here in MT, one is a late 99, the other a 2001(my truck has GPCM).
I opened up the boxes last night, and there are no numbers or anything indicating which posts are the hot feeed, etc. Was wondering if someone had a diagram of which is which, no real way to orient it except for the mounting bracket as to say which would be which?
Thanks, Tom
Old Dec 1, 2009 | 08:34 AM
jcrammell's Avatar
jcrammell
Here's Guzzle's link. Very well done and good instructions. I have mine sitting on the shelf. Waiting to install when PMS really sets in.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Dec 1, 2009 | 08:40 AM
onelionhunter
Thanks
Thanks, I knew it had to be around here somewhere, seems like half the folks here are running the stancor's.
Kind of funny, i buy a 7.3, find FTE, join, and now my fleet to maintain has grown to 3 trucks.......
Thanks, Tom
Old Dec 1, 2009 | 01:48 PM
IM1096's Avatar
IM1096
I just read Guzzle's Stancor GPR replacement page and was wondering about the "shunt" that is mentioned and pictured. What does the shunt do and is it necessary?
Old Dec 16, 2009 | 12:46 PM
richea33's Avatar
richea33
Just replaced OEM with Stancor after reading guzzles mod page. The replacement is easy, however the mounting studs are too long very nearly touch the stancor making it difficult to thread on a holddown nut. As Guzzle says, you'll have to place the stancor halfway on, then thread the nut before dropping the unit all the way down on the studs. Then you'll need a 10mm SHORT box end and some patience to get the nut secure. I recommend removing the front relay also as this will help, but like the holddown nut, the front relay also has to go on after the stancor, but before the unit is all the way down. Good Mod, I'll test in colder weather soon.
maevans
Feb 21, 2013 11:36 AM
stainlessstroker95
Dec 4, 2011 04:35 PM
IM1096
Dec 2, 2009 05:20 PM
Waltdog
Nov 9, 2009 06:09 PM
hedhntr
Oct 13, 2009 09:58 AM
