I traced the problem to a bad vss and the wiring that plugs into PO had the wire spliced diesel fuel got into the harness and created a goop that was shorting it out intermittently. worst thing was i had to lay on wet snow to fix it up areas roads still havent been plowed and it is pis#### people off!!
